Author Topic: Cloning a -71Challenger into a -70, technical questions  (Read 18006 times)
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: Cloning a -71Challenger into a -70, technical questions
« Reply #15 on: November 30, 2013 - 04:23:17 PM »
found these
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline johannes
« Reply #16 on: December 01, 2013 - 04:44:08 AM »
SUPER !!     :thumbsup:
Especially the volt regulator and ballast resistor holes were useful pieces of information.
Any chanse there are something similar for the holes on the inner fenders?  :clueless:
Offline 67vertman
  • Member since 9-23-2005
« Reply #17 on: December 01, 2013 - 07:53:00 PM »
Never seen anything like that........someone may have pictures of thier cars though.
Offline johannes
« Reply #18 on: January 30, 2014 - 05:04:17 PM »
Time for an update?
There is steady progress...
Close to 7k USD worth of parts soon crossing the Atlantic...
I'm now playing with ideas for custom leather doorsides, and STARS AND STRIPES paint job.
I sure could use some ideas. ANYONE?
Offline ShelbyDogg
« Reply #19 on: January 30, 2014 - 10:12:11 PM »
Being in the States, I would say no to the stars and stripes paint job. Maybe some race cars in the '70s had that look but you do what you want because it is your car. Are you that proud of owning an American car? All the true car guys know right away where that car is from.
Offline johannes
Cloning a -71Challenger into a -70, some pics
« Reply #20 on: March 13, 2014 - 09:11:29 PM »
Stedy progress on my project.
Had an "All inclusive weekend" at my restorer's garage last weekend.....
This include wrenching, mopar talk, good food, and late night drinking....PERFECT !!
Engine bay is complete.
We've done an upgrade to the rag top drain system, so that I now can park with the car facing uphill.
Can anyone remember if the soft top draining system has been discussed earlier?
...I'm interested in drainage path from the lower quarter (behind the doors).
One side is barely seeping out water, when testing by filling the "cavity beside the rear seat" with water...sorry for my poor vocabulary w.r.t. body parts..
Offline larry4406
« Reply #21 on: March 14, 2014 - 06:52:23 AM »
On E-body verts, there is a u-shaped channel that runs around the base of the top from quarter window to quarter window.  The ends of the channel are open.  Water simply drains out the open channel ends, into the inside of the quarter panel, and then out drains in the rocker pinch weld area.
Offline johannes
« Reply #22 on: August 26, 2014 - 05:22:37 PM »
Been a while since my last post......
Has anyone information related to the drainage in the " rocker pinch weld area"  ????
I get wet carpets near the rear seats when washing the car due to drainage problems...
I need to make rust repairs to the rocker panel... so I will cut open....
Anyone having pics of the inside of rocker showing what path the water shall take ??
Offline johannes
« Reply #23 on: August 26, 2014 - 05:39:18 PM »
New question.
My 70 tailligths housings has some corrosion... which will not show when installed.
I've used wirebrush for cleaning.
What else should I do ?
Offline Fern
« Reply #24 on: August 26, 2014 - 06:42:59 PM »
When I had my vert open I noticed that the drain holes in the bottom of the quarter were small and could get clogged up easely. I opened the holes up and blew high pressure air up through there and blew all the debris out. Might be why your getting wet carpets.
Offline ShelbyDogg
« Reply #25 on: August 27, 2014 - 08:50:14 AM »
Me too. My floor behind the passenger front seat would get wet when it rained. I took off the rear panel to see inside the right rear window area. I closed the convertible top, then used a hose to wet the car. The right rear window area filled with water then started to flow into the car.
When I welded in my new quarter panels, I left some big drain holes at the bottom. The sheet metal next to the rocker was too close and sealed up to let the water out. I cut a large drain hole on the outer side to let the water flow out.
Offline johannes
« Reply #26 on: September 26, 2014 - 05:39:09 PM »
No wonder my drain did not work...
https://www.youtube.com/watch?v=ZDjSIfaCVaw
When time permits, I'll make sure my 'Cuda does NOT develop similar rust issues ...
Offline johannes
« Reply #27 on: October 25, 2014 - 01:38:01 PM »
Hello again.
The car is comming together nicely ..... will get a paintjob done during November...
Same non original blue color that I fell in love with when I purchased this car back in -93.
The wipers need som TLC.
Both pivots and bushings are rather worn (Variable speed wipers, bronze bushings)
Does anyone know who can help me with this ?
Jules the Wiper Man..... passed away a year ago.... moderators can you update his profile ???
Not much info on wipers on this site since then....
Suggestions anyone ????
I'm selling the 71 grille and tail lights,..
http://www.finn.no/finn/torget/annonse?editAd=true&finnkode=52568433
But I guess shipping cost from Norway makes it awkward for non Scandinavians....
Offline johannes
« Reply #28 on: December 07, 2014 - 03:22:29 PM »
Gentlemen.
There is only one single torsion spring on my trunk lid... believe this is original on -71 ?
I'm not happy,.... as this means "twisting" of the lid.....
What can I do ?
Gas-springs?
Does anyone sell double springs?
Offline ShelbyDogg
« Reply #29 on: December 07, 2014 - 03:39:14 PM »
My 71 convertible also has the single torsion spring. I was unable to install it since the weld at the top of the support had broken loose and I did not discover this till after the car was painted. I have (2) 12" gas struts I am going to install also.
