Author Topic: Water temp gauge in center.. what degrees temp ?  (Read 994 times)
Offline Racer57
« on: September 11, 2013 - 09:49:06 PM »
70 Cuda with 383 4 speed, shaker hood
If the temp gauge is dead center, what temp would that be from the factory ? My mechanical gauge shows 190 degrees
Primarily curious how accurate my gauge is.
« Last Edit: September 12, 2013 - 08:43:09 AM by Racer57 »
Re: Water temp gauge in center.. what degrees temp ?
« Reply #1 on: September 11, 2013 - 10:34:12 PM »
I don't think the slow responding factory gauges were assigned a given temp for any particular mark, I will say that my car usually ran just a shade below the middle of the solid section and would creep up to a shade above the middle under more extreme conditions. Car only truly overheated once & it defiantly was above the solid middle area.
« Reply #2 on: September 12, 2013 - 04:17:43 PM »
Mine is always below mid-point, but I have a 26" radiator with the AC removed, so no extra load on the system.
If your mechanical gauge tells you 190, that's great. Even up to 200 is fine.
Offline DocMel
« Reply #3 on: September 12, 2013 - 04:32:42 PM »
A common misconception is that anything above 190 is too hot,  200-220 is considered a good running temp
Offline Racer57
« Reply #4 on: September 12, 2013 - 04:34:32 PM »
I understand that 190 is ok, what I want to know is what degrees the center reading is suppose to be.
« Reply #5 on: September 12, 2013 - 04:49:53 PM »
If it helps....? mine runs in the middle of the gauge (1970 standard dash) at 190? I don't knowe if that's "stock" or not?  :dunno:
