Author Topic: What other body styles axles will fit under my cuda?  (Read 594 times)
Offline EMCD
« on: September 12, 2013 - 11:29:52 AM »
Is the B body a direct fit that will allow me to run 10" tires?
Re: What other body styles axles will fit under my cuda?
« Reply #1 on: September 12, 2013 - 11:34:02 AM »
68-70 B body yes , 66-67 I believe are different & 71 up are much wider
Offline EMCD
« Reply #2 on: September 12, 2013 - 12:36:54 PM »
The guy is saying the housing is 56.5" long, with axle lengths of 20". This sound right for a late b body?
Offline 70CUDA4SPEED
« Reply #3 on: September 12, 2013 - 03:16:22 PM »
56.5" is an E-body rear, B-bodys are 55" and axles are 28" if I'm correct, and you will need a http://www.doctordiff.com/e-body-offset-spring-hanger-shackle-kit.html because perches are 44" not 46 as on a E-body.
« Reply #4 on: September 12, 2013 - 03:21:17 PM »
My friend has just installed a 67 B-body axle with The kit from Cass and he uses this rims http://www.summitracing.com/parts/cll-005105545/overview/
« Reply #5 on: September 12, 2013 - 06:58:29 PM »
