Author Topic: E-body dome light wiring routing pic needed  (Read 1119 times)
Offline Katfish
  • 70 Challenger
« on: September 14, 2013 - 09:41:13 AM »
I'm replacing the rear lighting harness in a 70 Challenger.
Dome light circuit is included on the harness.
My headliner is already in, so I'm not sure I can snake out the original and replace with the new.
Need to know if the factory wiring has clips or goes in or around anything?
Thx
Re: E-body dome light wiring routing pic needed
« Reply #1 on: September 14, 2013 - 10:08:00 AM »
the dome light has a connector above the rear wheelwell so you can replace the rear harness & use the existing dome light harness
Offline Katfish
  • 70 Challenger
« Reply #2 on: September 14, 2013 - 10:30:32 AM »
You sir, are a life saver!  This project just got a little easier.
Thanks so much!
« Reply #3 on: September 14, 2013 - 01:13:35 PM »
I don't have a hole in the middle but I do try  :2thumbs:
