Author Topic: ANOTHER Turn the key and key and get nothing post!  (Read 3212 times)
Offline Barracudadan
Re: ANOTHER Turn the key and key and get nothing post!
« Reply #15 on: September 17, 2013 - 09:09:38 AM »
I would just fill the torn boot with silicone ?
Yeah that's probably what I will do, I think a small piece of rubber hose over the tranny lines where it rubs,to help keep any bare metal contact from happening can`t hurt either. Thanks!
Offline Strawdawg
    • Vortex Buicks
« Reply #16 on: September 18, 2013 - 09:49:39 AM »
Yep I had a screwdriver didn`t turn over just sparked.
Thanks Strawdawg Is this how I jump it? I made a couple notes in the pic.
 I used to know how to do this on a 67 Cougar back in the day but I forgot how to do it, the NSS was bad on that car too. I think I also had to run a wire from the solenoid to the + side of the coil to keep it running does that sound right? I wont do all that now I`ll just replace the bad part when I figure out what is bad.
That would be correct.  But, it seems you have established the problem is at the starter so it is not needed now :)
Hit the starter with a hammer a couple of times and see if it cranks :) Sometimes this works but is not a fix.  I think Chryco is right about what is probably wrong
« Reply #17 on: September 19, 2013 - 05:41:24 PM »
Oh don`t you worry, I hit it with a hammer a few times! Should it have still been in the car when I did that?  :smilielol:
