My car is a N95 car. Do I still need CR8E tank? What was the emissions on the car? My tank is gone but the four tubes are still viable from the underside
My guess would be that the vents coming from the gas tank are routed through the 4 vent tubes on the unit coming out of the trunk. If you remove the 3 screws on the unit on the right side of the trunk you can see how those 4 lines are all crossed. I also have a N95 car.
If you get a new tank I would just get as mentioned below the emissions tank with the four vent tubes and just run 3/8 lines to the unit in the trunk. There should also be a piece of sheet metal covering up those lines if you looked in the wheel well. Connects by two screws,
