Author Topic: Trans crossmember difference  (Read 537 times)
Offline moparstyle
« on: September 16, 2013 - 07:37:31 PM »
My trans crossmember is kind of hacked up so i will get a new one.
Brewers webpage lists 2 versions, 70-72 and 73-74. Anyone knows the difference between these 2?
72 Challenger, 440 stroker, 727 (70 clone)
70 Barracuda Gran Coupe
And on the side:
67 Pontiac GTO
63 Lincoln Continental
Offline anlauto
Re: Trans crossmember difference
« Reply #1 on: September 16, 2013 - 08:00:42 PM »
The four mounting holes are different spacing...The newer ones are narrower...
TIP: When looking at a 1970-71 E Body that you suspect might have been rebodied using a newer shell....Always check the tranny crossmember because the whole crossmember is different as well as the mount.
Offline moparstyle
« Reply #2 on: September 16, 2013 - 08:31:02 PM »
You are fast.... Thanks!
And on the side:
67 Pontiac GTO
