Author Topic: Mopar lighting problem  (Read 937 times)
Offline mrbill426
    • All Around Mopars
« on: September 16, 2013 - 11:34:06 PM »
No it's not an E-body but it's still a Mopar  :)
 :1zhelp:  We're dealing with a '73 Satellite wagon that suddenly has no tail lights, parking lights, side markers, or dash lights, but the headlights, brake lights, and turn signals work fine.  Other odd thing is when the headlights are turned on the dome light also comes on very dimly.   :clueless:  The dome light comes on bright when the doors are opened or if turned on manually.  The headlight switch was replaced, with no change.  No blown fuses found either.
Anyone have any ideas what the problem could be?
Thanks!
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Re: Mopar lighting problem
« Reply #1 on: September 17, 2013 - 12:05:57 AM »
start tracing power , my bet is a bad headlight switch
Offline mrbill426
    • All Around Mopars
« Reply #2 on: September 17, 2013 - 12:15:47 AM »
Thanks, we're probing around.  We suspected the switch and replaced it anyway since it was the original; had no effect on the problem.  :(
MOPAR or NO car!
Offline 73EStroker
« Reply #3 on: September 17, 2013 - 02:10:03 PM »
Might be the firewall plug. I believe the tail and headlight circuits travel through that plug separately and they join in the switch up top. You need a wiring diagram to verify and you can get that on mopars.org I believe.
Barry (Salmon Arm)
« Reply #4 on: September 19, 2013 - 08:09:03 PM »
Most of the lighting is fused except for the headlights
Offline mrbill426
    • All Around Mopars
« Reply #5 on: September 20, 2013 - 09:41:24 AM »
Thanks for the input folks.  :wave:  A fuse that looked fine turned out to be bad with a test light; fuse replaced, lights work!  :thumbsup:
MOPAR or NO car!
« Reply #6 on: September 20, 2013 - 02:51:46 PM »
 :2thumbs:
