Author Topic: Need Help with Challenger TA Power Steering Box Questions  (Read 1840 times)
Offline citadel
« on: September 18, 2013 - 11:26:49 AM »
Guys,
I am looking for a correct power steering box for my 70 TA Challenger. It is one of the few parts on my car that is not correct/ matching.
Does anyone have a picture of the correct unit?
Is there more than 1 correct power steering box for the 70 TA? I was told there was a power steering box and also a fast ratio power steering box for these cars...?
On my build sheet in the box for power steering, there is a "7".
Offline citadel
Re: Need Help with Challenger TA Power Steering Box Questions
« Reply #1 on: September 18, 2013 - 12:31:59 PM »
Here is a pic of the current box on the car.
Offline anlauto
« Reply #2 on: September 18, 2013 - 06:38:57 PM »
If you bought the car I think you bought from LMC, then it was NEVER equipped with Fast Ratio steering from the factory.
 That is the correct box for that car code S77. Fast Ratio is code S74. :2cents:
Offline citadel
« Reply #3 on: September 18, 2013 - 09:00:30 PM »
Hi Alan,
In Mauro's inspection he noted the steering box as being incorrect? The broadcast sheet states standard power steering  S77.
Maybe he was looking for "TA" stamped on the box? I am guessing only the TA fast ratio steering (S74) has "TA" stamped on the side...? thoughts?
« Last Edit: September 18, 2013 - 09:02:18 PM by citadel »
Offline anlauto
« Reply #4 on: September 18, 2013 - 09:09:31 PM »
Yes, Maruo most likely assumed that the car was coded for a T/A box.
Offline citadel
« Reply #5 on: September 18, 2013 - 11:39:48 PM »
cool. That is good news. Is there any part number or such that I can look at to confirm it is the right box? I just want to be certain.
Offline AARuFAST
  • AARuFAST
« Reply #6 on: September 18, 2013 - 11:46:26 PM »
TA STAMPED ON BOX
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
Offline Cuda Cody
  • Vancouver, WA
« Reply #7 on: September 19, 2013 - 12:44:04 AM »
Like Alan said, you could get from the factory both power steering and fast ratio power steering on T/A's.  If you have a "7" in the power steering box you did not have a fast ratio.
Offline anlauto
« Reply #8 on: September 19, 2013 - 06:48:47 AM »
2267 262 should be cast into the non-T/A power steering box.
« Reply #9 on: September 19, 2013 - 07:15:36 AM »
 So the T/A box what made it fast ratio, I thought it was just the arms?  What's the differences between the 2?
Offline citadel
« Reply #10 on: September 19, 2013 - 11:16:57 AM »
thanks Alan, I will check for the correct number on the box to be sure
