Author Topic: MOPAR part numbers for wiper arm and crank  (Read 2466 times)
Offline MR291
« on: September 18, 2013 - 12:24:08 PM »
I am installing a three speed wiper setup in my 70 Cuda.  I bought the pieces but I am having difficulty with the crank and the bushing in the linkage arm.  Stud on crank is not long enough or bushing is incorrect.
There seems to be a lot of different numbers out there for what will work in the car.  There used to be site "lighteningjar" that had a great search engine for confirming parts / interchangeability but that is no longer working.  Is there anywhere else that I can match the numbers on my pieces to confirm whether they are correct or not.
The linkage arm is 3431 514 58622 and the crank is 2822 28 58622.
Thanks.
Re: MOPAR part numbers for wiper arm and crank
« Reply #1 on: September 20, 2013 - 08:47:19 AM »
contact Kim at Passion 4 Mopars , she will have all the info you need
Offline mrwfp
« Reply #2 on: September 20, 2013 - 11:03:51 PM »
I have a wiper arm # 3431 514 58622 and was told by Kim that it is a 2 speed arm.
Offline JayBee
« Reply #3 on: September 21, 2013 - 09:22:22 AM »
I looked this up in my 70/71 Parts Catalogue and your "3431 514" doesn't show up. It's probably from later years. I also did this conversion on my car and the correct part numbers for the var/3speed are:
2822 293 - link that goes from motor's crank to left pivot
2822 289 - crank coming off the motor
John
1970 Barracuda convertible
2014 Toyota Avalon
