Author Topic: Turn signal lever slop  (Read 793 times)
Offline 73RallyeChallenger
« on: September 18, 2013 - 08:06:34 PM »
Wonder if someone can tell me what is wrong with my turn signal lever. It functions, but the problem is it has too much slop, or play. Also when I click the lever, it clicks really hard to the point where I think I'm going to break it. Is there a part missing that is causing this, or is it a faulty or bad repo turn signal switch or cancel cam?
Offline Falbz
Re: Turn signal lever slop
« Reply #1 on: September 18, 2013 - 09:00:41 PM »
The slop in the lever is probably due to the screw coming loose. Just tighten it and you should be good to go. I bet that will fix the click issue since the lever has notches that sits in between the turn signal switch.  If you need a new switch part # is TW7 from standard motor products.
Here is a thread with some pictures
http://www.cuda-challenger.com/cc/index.php?topic=82394.msg825283#msg825283
Hope it helps
« Last Edit: September 18, 2013 - 09:03:31 PM by Falbz »
« Reply #2 on: September 19, 2013 - 05:13:28 PM »
I had to use Locktite to keep my turn signal lever from coming loose constantly.
