Author Topic: Priming oil pump, which way does it turn?  (Read 4613 times)
Offline Chlngrcrzy
« on: September 19, 2013 - 08:51:56 PM »
Before I get to involved with something else, I need to get this motor running. I want to use one of the priming tools to stick down there and turn the oil pump. Which way does the rod need to turn the pump? Will it hurt anything if the pump is turned the wrong way? If I remove the oil pump, can I reach up in there and knock out the brass bushing the distributor intermediate shaft sits in?
Offline anlauto
Re: Priming oil pump, which way does it turn?
« Reply #1 on: September 19, 2013 - 09:32:39 PM »
I don't want to sound too obvious, but your distributor is driven by the same gear/shaft as your oil pump so I'm guessing  it rotates in the same direction as the distributor.  :thumbsup:
« Reply #2 on: September 19, 2013 - 09:40:19 PM »
Distributor on big blocks is counter clockwise. Spin the drill in reverse.
When you begin the priming, it'll go at first effortlessly, then all of a sudden it'll feel like the drill went under load. That's how you'll know oil is beginning to pump up.
Watch your rpm's. Nice and steady and not to fast. Rotate the crank once it starts coming up at the heads and repeat again every 90 degrees.
Offline cudabob496
« Reply #3 on: September 19, 2013 - 11:07:18 PM »
put a temp oil gauge on the block.
I rotated my crank 30 degrees, got oil pressure
up to around 60 I think, with the variable speed drill,
held pressure for a minute, then rotated crank another
30 degrees, and repeated process, untill crank rotated 360 degrees.
2011 Kawasaki Z1000
Offline dutch
« Reply #4 on: September 20, 2013 - 12:18:26 AM »
if possible,  use a drill with one of those oldschool tightening systems ( no clue what they are called in english... lest say a gear/pinion wrench  :bigsmile:   In reverse the others will come loose.  Alse hold on to the drill,  it can really bite.
*** Bart ***
« Reply #5 on: September 20, 2013 - 08:40:58 AM »
All big blocks turn counterclockwise
All small blocks turn clockwise
Offline Chlngrcrzy
« Reply #6 on: September 20, 2013 - 10:03:24 AM »
Thanks guys. i have never done this before. i am one of those guys that a Mopar for Dummies book would be a great idea.     :worshippy
Offline HP_Cuda
  • Mopar or No Car!
« Reply #7 on: September 20, 2013 - 12:16:55 PM »
I've also heard folks removing the spark plugs and cranking it to get the oil moving around before initial startup.
The drill is a nice easy way to do things though.
Offline Aussie Challenger
« Reply #8 on: September 21, 2013 - 10:42:06 PM »
You also mentioned about replacing the support bush, check how much wear first it may be alright. A link to a thread about the bush is below.
  http://www.cuda-challenger.com/cc/index.php?topic=94592.0
   David
   Aussie Challenger
Offline jimynick
« Reply #9 on: September 28, 2013 - 12:32:34 AM »
I think you'd call it a "keyed drill chuck" Bart.  :wave:
Offline dutch
« Reply #10 on: September 28, 2013 - 10:39:27 AM »
 :thinkerg:   :cheers:
*** Bart ***
