Author Topic: 383 carb question  (Read 804 times)
Offline tunerwannab
383 carb question
« on: September 22, 2013 - 12:45:54 AM »
I looking at changing the carb on my 71 challenger. It has a 383. Don't know exact motor details, previous owner told me he did the biggest cam he could without messing with valves, it does have a mopar performance intake manifold and headers.
Currently I have a Holley 600 I think, no choke, I forget the exact model but it is not a common or popular one. I'm undecided between an edlebrock 600 or 650 with electric choke. Currently the car will cruise fine but when cruising if I give it more gas it chokes for a second then goes. Any tips advice would be awesome. I trying to do this Tuesday.
Offline cudabob496
« Last Edit: September 22, 2013 - 03:31:57 AM by cudabob496 »
2011 Kawasaki Z1000
Re: 383 carb question
« Reply #2 on: September 22, 2013 - 08:45:50 AM »
I would be looking at a 750 Proform carb
Offline tunerwannab
« Reply #3 on: September 22, 2013 - 11:09:03 AM »
Looking at that chart I wouldn't think my car runs at 100% efficiency. Is it better to have a too much carb than to little.
« Reply #4 on: September 22, 2013 - 12:09:44 PM »
How many times have we had this discussion ! The best formula for picking a carb is 2x the CI so 383 is 766 .
 True you cannot change physics but maybe the carbs do not flow as much air as advertised but real world experience is approx. 2x the CI works well .
Proform has one of the most affordable & tunable carbs on the market with vacuum or mech secondary .
The reality is the Holley you have can be tuned to work well also , check float levels , change the squirter or pump cams , replace the secondary spring or use the correct power valve & the hesitation will disappear .
Offline 72cudamaan
« Reply #5 on: September 22, 2013 - 01:46:50 PM »
 True you cannot change physics but maybe the carbs do not flow as much air as advertised works well .
Neil, say it ain't so.  :roflsmiley:   Manufacturers advertising falsely. That couldn't happen.   :wow:   I agree with the 2x
formula as well.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline jhaag
« Reply #6 on: September 22, 2013 - 10:37:04 PM »
I agree with chryco. try to fix what you have unless you need the choke. as to your question on whether to error on the small or larger cfm size, on a street car you will get better throttle response and driveability with a slightly undersized carb over 1 that is too big. if your carb has the choke horn still on it, it will have a number stamped on it, go to holleys' web site and you can figure out exactly what you have, then work from that
love 70 Challengers
Offline cudabob496
« Reply #7 on: September 23, 2013 - 12:15:37 AM »
I agree, a well dialed-in 750 supported my old built 440 to well over 500 hp.
If he didn't take his challenger above 5500 rpm, then a 650 would probably make him
quicker on the street.  A 750 on his 383 would be necessary if he was taking it
up to 6000+ rpm.
Though a much different engine, the 850 hp NASCAR car engines use an 830 cfm carb. They are probably
as close to a volumetric effeciency of 1.0 you are gonna get. I think you go above 1.0 when you have
a blown or turbo engine.
« Last Edit: September 24, 2013 - 10:59:43 PM by cudabob496 »
2011 Kawasaki Z1000
