Author Topic: priming oil pump  (Read 483 times)
Offline rattlesnake
  • Rattlesnake
priming oil pump
« on: September 23, 2013 - 08:58:26 PM »
When priming the oil pump on the 440. I have the resistance on the drill I think is proper. How do I know when it is primed enough? Should I have oil coming all the way up to the rockers or even in the oil pressure hose? When do I quit?
Thanks Ray
keep honking I'm reloading
Re: priming oil pump
« Reply #1 on: September 23, 2013 - 09:31:50 PM »
30 seconds will fill everything except the rocker shafts , you have to rotate the cam the exact right position to feed up to the shafts , it is only fed every second turn of the crank & even then it has to be in the exact position to line up the 2 holes
Offline rattlesnake
  • Rattlesnake
« Reply #2 on: September 23, 2013 - 10:22:03 PM »
praciate u psycho
Offline cudabob496
« Reply #3 on: September 23, 2013 - 10:52:25 PM »
I put a temp oil gauge on the block.
I rotated my crank 30 degrees, got oil pressure
up to around 60 I think, with the variable speed drill,
held pressure for a minute, then rotated crank another
30 degrees, and repeated process, untill crank rotated 360 degrees.
2011 Kawasaki Z1000
« Reply #4 on: September 23, 2013 - 11:32:34 PM »
I recently read on the Internet How one person recommended To fill the oil shafts with oil and gob grease to hold in there Until the engine fires.
