Author Topic: Start/run circuit  (Read 1115 times)
Offline A110235
  • '71 Challenger JH23G1B
Start/run circuit
« on: September 25, 2013 - 11:10:43 AM »
I am hooking up the brain for my fuel injection system in my '71 Challenger and the instructions say I need to power it with a circuit that has 12V during cranking and running.  Is there even a wire that has that?
Kyle
Nashville, TN         Member since October 09, 2004
Offline rattlesnake
  • Rattlesnake
Re: Start/run circuit
« Reply #1 on: September 25, 2013 - 01:47:40 PM »
Don't know how much power your looking for and not familiar with fuel injection needs, but there are a few circuits that have power when cranking and running. Lighting circuit for one, there are also a few plugs on your fuse box that can be utilized.
keep honking I'm reloading
Offline A110235
« Reply #2 on: September 25, 2013 - 02:47:12 PM »
I don't know how much power it will use either.  It was a small wire (maybe 18 gauge) and it think it is used to sense when you are trying to start the car, not actually power the unit.  It had like a 12 gauge wire for main power.
I got tired of laying on my back under the dash with a flashlight with my meter trying to see what had power and when.  I'll have to scope out the lighting circuit.  Thanks for the info rattlesnake!
Kyle
« Reply #3 on: September 25, 2013 - 05:58:11 PM »
you can tie into the wires either at the bottom of the column or at the ballast resistor , they will be brown & blue , brown is start blue is run & both need to be connected . It just trips the relay for the main power from the battery ,very light load .
« Last Edit: September 26, 2013 - 07:02:34 AM by Chryco Psycho »
Offline 67vertman
  • Member since 9-23-2005
« Reply #4 on: September 25, 2013 - 11:37:09 PM »
That is how I ran mine (ballast resistor), 1 year in no issues.  :clapping:
Offline A110235
« Reply #5 on: September 26, 2013 - 09:08:11 AM »
Alright, thanks guys!
Kyle
« Reply #6 on: September 26, 2013 - 06:29:38 PM »
:clueless: What do you mean 'trips the relay?'
« Reply #7 on: September 26, 2013 - 09:45:10 PM »
most Msd & computers use a 12 ga wire to feed power from the battery or similar such as power at the start relay , the smaller gauge wire that connects to the start run feed is usually 18 ga & just switches on the power inside the MSD or computer using a relay
« Reply #8 on: September 28, 2013 - 07:40:30 AM »
Oh OK. I was thinking 'outside the box'  :cheers:
