Author Topic: Lots of Mopar parts  (Read 4325 times)
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
Lots of Mopar parts
« on: April 02, 2005 - 12:20:37 PM »
I was searching for parts for a fellow board member and cae across a bunch of ads I thought you guys might want to see.  There are even a few Hemis in the list and a 70 Cuda fender, as well as a bunch of other good stuff.  Here ya go.  Oh, 4C, there is a black console in this list if you are still looking for one.
 PLYMOUTH DUSTER 340 GRILL,
 Shark Tooth, exc shape, $400. (917) 709-8147 . New York
 MOPAR TRANNYS,
 two 727, cores only $75 each; 8 3/4 2.92 open chunk, $75; 10'' B body complete front drum set up, $75; Ford 302 5.0 disassembled long block roller motor, $125; AOD core with converter, $75, open to ALL offers. (860) 420-8512 (4x) .
 MOPAR PLYMOUTH DUSTER FENDERS,
 70-72, also black int panels, $100; windshield for same, $75. (718) 614-2552. New York
 MOPAR PARTS:
 Sliding factory SUNROOF complete-$500, Set of 14x6 Magnum 500 wheels, 2 with new BF Goodrich tires-$400, 71-74 K-frame-$200. (631) 421-0741 BEFORE 2PM (2x). Huntington
 MOPAR PARTS,
 70-74 MOPAR CUDA RALLYE HOOD, 72-74 fenders, left and right, flawless, absolutely mint and straight, can email pictures, Super Stock springs, P3690460 right, P3690461 left. (203) 217-6783 (2X). Waterbury
 MOPAR PARTS,
 70-74 Cuda black door panels, fronts & rear, good cond, best offer. (203) 261-5604 or cell (203) 305-2113. Trumbull/Easton
 MOPAR PARTS,
 68 Dodge Charger parts, console, dash, doors, many misc items. (203) 261-5604 or cell (203) 305-2113. Trumbull/Easton
 MOPAR PARTS,
 new Challenger stock flat fiberglass hood, $250; new 8" Torpedo hood scoop, $70; B & M & Hurst auto shifters, $50 ea; Jazz 400 racing seat & cover, $50; more. (631) 648-7447.
 MOPAR PARTS,
 new fiberglass hood for 70-74 Challenger, 8" Torpedo hood scoop, $275; new B & M and Hurst quick silver auto shifters, $50 ea; 340 4 bbl intake manifold, $75 each. (631) 648-7447 .
 MOPAR PARTS,
 cylinder heads, closed chamber, #516, ready to install, $250; 8 3/4" housing for E body, $200. (914) 670-2718 . Cell
 MOPAR PARTS,
 disc brake setupw/lower control arms & sway bar, fits 70-74 E bodies & 71-74 B bodies, $400; K frame, 70 B body skid plate, $400. (914) 670-2718 . Cell
 MOPAR PARTS,
 68 Dodge charger, bucket seats, $150; Bare J heads, good cond, $100. (203) 261-5604 or cell (203) 305-2113. Trumbull/Easton
 MOPAR PARTS,
 68-70 B body 26" non air core support, $100; 15 x 7 non rallye steel wheels, off 80s Fifth Ave, $25 ea; Police Interceptor 15 x 7 cap wheels, $30 each. (603) 209-1678.
 MOPAR PARTS,
 ss leaf springs 66-72, $120; 73-74 B body, spindles, rotors, calipers, more. (646) 523-0857 .
 MOPAR PARTS,
 440 valve covers, Mickey Thompson, w/Keith Black breathers, $200 OBO. (203) 576-0455. Bridgeport
 MOPAR PARTS,
 engine code #E48 police interceptor 318 w/340 Xheads, approx 9K mi on engine since rebuilt, can demo, made into 904 auto trans, also rebuilt w/redline clutches, more, $2000. (631) 648-7447.
 MOPAR PARTS 70-74 Challenger doors, left and right, very good condition, no rust, $100 ea; new fiberglass hood for same, includes 8" torpedo hood scope, $275. (631) 648-7447.
 MOPAR K-FRAME,
 1970 B-body skid plate, $400; cylinder heads, closed chamber #516, ready to install, $250; 8 3/4'' housing, E-body, $200. (914) 835-2702 Burt. Harrison
 MOPAR HIGH BUCKETS,
 fits 71-74 Charger, one clean, one has rips, drivers side power, black, $275. (631) 395-3148 . New York
 MOPAR FAN SHROUD,
 66-69 B body, new, $75. (203) 576-0455. Bridgeport
 MOPAR E BODY RALLYE STEERING WHEEL,
 good condition, call for more information. (845) 216-3084 Westchester County. New York   Delete
 MOPAR E BODY CONSOLE,
 black, good shape, $200. (718) 614-2552. New York
 MOPAR DISC BRAKE SET UP,
 with lower control arm and sway bar, fits 70-74 E body and 71-74 B body, $400. (914) 835-2702 Burt. Harrison
 with lower control arms & sway bar, fits 70-74 E body & 71-74 b body, $400; K frame, 70 B body skid plate, $400; cyl heads, closed chamber, #516, ready to install, $250. (914) 835-2702 Burt. Harrison
 MOPAR CHALLENGER RT HOOD,
 vgd cond, $350. (631) 395-3148. New York
 MOPAR BATTERY,
 reproduction, Group 27, with red caps, $85. (203) 929-1198 . Huntington
 MOPAR 8 3/4 CENTER SECTION PUMPKINS,
 alll different gears, all different housing numbers, B or E body K frame with anti sway bar and 11" drums, $100; various Mopar rears. (718) 614-2552. New York
 MOPAR 70 PLYMOUTH SPORT FURY
 taillights, NOS in box, Mopar Rallye rims. (845) 216-3084 Westchester County. New York
 MOPAR 440 HEADS,
 number 906, $300 OBO. (860) 295-0772. Marlborough
 MOPAR 426 MAX WEDGE DUAL QUAD
 intake manifold, mint cond, $1500. (631) 395-3148. New York
 MOPAR 4 SPEED TRANS,
 with shifter and most linkage, fits A body, $675. (631) 395-3148 . New York
 MOPAR 360 ENGINE,
 $300; SB 727, $300; SB complete 4 spd setup, $500; 318 truck engine, $250. (845) 331-7819. New York
 MOPAR 340 BLOCK,
 clean and ready to build, ARP head studs, 770 casting date, 40 over with J heads and forged steel crank shafts, $500. (718) 614-2552. New York
 HEMI ENGINE,
 392-426 Keith Black alum, various parts, call for prices. (631) 585-1183. New York
 ENGINE,
 440 Chrysler supercharged, w/Ross Speed Pro Isky, Dyers manifold & drive,Fontana blower, machined iron heads, steel crank steel rods, balanced assembly o-ringed, $9500. (631) 794-2021.
 CHRYSLER HEMI 392 ENGINE PARTS,
 4 barrel intake manifold, water crossover, exhaust manifolds, rocker covers, valley cover, all jet hot coated silver, distributor plus misc items, all in exc cond. (203) 215-1564 Joe. Cell Phone
 71 PLYMOUTH DUSTER TRANNY,
 4 speed, with Hurst Comp Pistol Grip Shifter, flywheel, bell, linkage to convert auto into 4 speed, even have hump from Mopar A body, $800. (917) 709-8147 . New York
 70-71 MOPAR CUDA OR CHALLENGER,
 Shalcor hoods and trim ring in primer, flat hoods required when purchasing, used as trade, $1750 with your good flat hood core. (603) 209-1678.
 70 CUDA LEFT HAND FRONT FENDER,
 cleaned & primed, straight, needs little work. (203) 261-5604 or cell (203) 305-2113. Trumbull/Easton
 69 BARACUDA FASTBACK PARTS,
 doors, hood, etc. (860) 355-3874. New Milford
 69 & UP DODGE DOOR SKINS,
 NOS. (203) 395-8580. Huntington
 392 CHRYSLER HEMI,
 supercharged & injected, can set up for Alky Gas Nitro w/Fontana, Enderle Bird Weiand manifold & complete drive Fontana blower machined, iron heads, steel crank, etc, $16,500. (631) 794-2021.
 392 CHRYSLER HEMI ENGINE PARTS,
 silver coated valve covers, rocker valley cover, exhaust manifolds, 4 barrel manifold, water pump, distributor, exc cond, $8500. (203) 215-1564 Joe . Cell Phone
 1970 MOPAR 340 MOTOR,
 everything new, 30 over forged pistons, purple cam, chrome molly rings, double roller timing chain, too much to list, motor is still on stand, professionally rebuilt, $2500. (917) 709-8186 . New York
Offline Street_Challenged73
Re: Lots of Mopar parts
« Reply #1 on: April 02, 2005 - 05:53:01 PM »
Dang, that '70 340 for $2,500.00 sounds like one crazy deal!!!
  • Global Moderator
« Reply #2 on: April 02, 2005 - 05:58:48 PM »
I said the same thing about that 340.
