Author Topic: Corroded terminal!  (Read 928 times)
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
Corroded terminal!
« on: September 25, 2013 - 04:58:24 PM »
Please take a look at this and tell me what you think.   I installed an MSD ignition a few weeks ago and on their harness they had these slip connectors going onto lugs bolted to the coil.  I knew it was a bad idea but went with it.  So this morning my car died.  Luckiily it was in my neighborhood with no traffic and not last night in the dark on the way home or somewhere dangerous.
So, is this simply a matter of a loose connection creating an arc and welding away the metal, or is there a more serious situation going on here?
I've since crimped, soldered, and shrink tubed on some proper connectors onto the wires and bolted them to the coil.  Like the rest of the system.
Here is the picture.  These were bolted to the coil and the one corroded away is the negative wire.
« Last Edit: September 25, 2013 - 05:00:17 PM by tonefiend »
Re: Corroded terminal!
« Reply #1 on: September 25, 2013 - 05:59:12 PM »
Maybe a loose connection arcing
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #2 on: September 25, 2013 - 06:15:40 PM »
Yes that's what I am 99% positive it was because when I put it together those connections were not exactly super tight.  Unless there is some other reason that can happen I'm going with a loose connection and anticipate no further problems.
Offline jhaag
« Reply #3 on: September 25, 2013 - 11:22:32 PM »
yup, that is burnt from arcing, not corrosion. I agree it was loose
love 70 Challengers
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #4 on: September 25, 2013 - 11:37:14 PM »
Thanks guys this won't happen again. I crimped and soldered on a thicker lug and now it's bolted down tight.
« Reply #5 on: September 26, 2013 - 07:01:05 AM »
 :2thumbs:
« Reply #6 on: September 28, 2013 - 07:44:01 AM »
Those spade lug connectors can be tightened up by gently squeezing it with a pair of needle nose pliers.  :2cents:
Have to do that at work on electric motor drive circuits from time to time.
