Author Topic: Floor Console Light Question  (Read 572 times)
Offline Recovering Cuda
« on: September 26, 2013 - 03:19:37 PM »
Greeting gents.   I have an issue.  I have a 1973 'Cuda and and am in the middle of replacing the console shifter plate and shifter handle.  Now the light that plugs into the shifter plate does not work.  I checked the blub and it looks good.  Just in case I got another blub to check it and it didn't work either.  So now I'm gonna have to trace the wire, which I started to do.  Now, I pulled on the wire and was able to pull about 8" of slack (through the opening in the carpeting for the shifter) before it got taught.  But here is the issue.  I appears that the wire is trailing back to the rear of vehicle instead of going toward the front or dash.  So my question is does anyone know where this wire (its ORANGE) connects to the harness?  I thought it should go forward to tie into the under dash harness.  I'm trying to keep from removing both seats and carpet to find out what is going on.  PO has done some other things that required repairing (cut wires to fender marker lights, etc) so I would like to know how its "supposed" to be tied into the harness.  If it makes any difference, this is not a rallye dash.
Thanks for your time and info
Offline anlauto
Re: Floor Console Light Question
« Reply #1 on: September 26, 2013 - 03:30:18 PM »
Take off your passenger side kick panel. It should be connected to an orange wire under the kick panel.
Offline 7212Mopar
« Reply #2 on: September 26, 2013 - 03:48:53 PM »
This orange wire from shifter goes to the front turn right toward the passenger side kick panel. If you take the passenger side kick panel off, you will this wire and the connector. Light should turn on when you turn on the parking light and/or headlight. I think connector needs to be grounded so check if you push the socket in and is tight. Test it with a volt meter.
I need to troubleshoot my map light. I think I have a bad switch.
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ,  6 spd
« Reply #3 on: September 26, 2013 - 05:28:03 PM »
Thanks for the info fella's.  As usual this site has saved me a bunch of time and headaches.  Many thanks.   If I have and more issues with this I will be back.
Have a good one!
