Its pretty straightfoward, make sure you have the correct shifter mechanism, levers, and rods. The only tip I have for you is to use a drillbit to line the shifter mechanism levers up(theres a small hole for this on the mechanism), than adjust the rods accordingly. You may have to adjust them more than once, it took me two times before it stopped crossing the gears. Ohh and the levers on the trans have two holes, the ones that are closer to the lever are for short throws and the ones farther are for long throws. Good luck.
