Author Topic: FINALLY, a clean run down the track with my Challenger  (Read 5718 times)
Offline BB73Challenger
« on: September 29, 2013 - 08:02:08 AM »
Just had to post, for a little back story I had bought a 499 ci engine from a member on here a few years back.
After some personal delays and a faulty fuel delivery system I finally got a good run out at the test and tune last night.
12.9 @113 - that beat what I thought I'd do.
The Challenger is a full street car with a 4 speed.
What a blast... too bad I didn't expect to make that good of a run and now I need to get a little more safety gear before the next run.
I didn't even bring a helmet!
Jeff from Cleveland, Ohio
Offline Katfish
  • 70 Challenger
Re: FINALLY, a clean run down the track with my Challenger
« Reply #1 on: September 29, 2013 - 09:26:07 AM »
Very nice! 60' time is pretty good too.
What kind of tires, what RPM did you launch?
Offline 422STROKER
  • Member Since 6/3/06
« Reply #2 on: September 29, 2013 - 10:16:50 AM »
Way more in it I hope. :bigsmile:  Otherwise you should have run a small block... J/K
Tom :burnout:
Tom
« Reply #3 on: September 29, 2013 - 10:53:10 AM »
Tom :burnout:
 :crazy: Yeah There should be a little more.
Keeping me on my toes huh?
I amazingly enough got a decent 60' for my hockey puck street radial tires.
They are Firestone Indy 500's and they are pretty hard, the 1st time I had it out I sent them in a spin thinking at the track I would have a little more bite. Definitely can't "dump" the clutch with them ( or any street tire for that matter )
To sound like a complete rookie I was so nervous about blowing the tires off at the start line I did the launch by feel.
Didn't look at my tach or anything, just feathered it out.
The last time I had the car out, I had a fuel starvation problem, spun through 1st and ran the carb empty by the top of 2nd.
Not a good outing.
So I thought I'd get out there and try for the 13's and work from there.
Well like said I ran out of the box better than expected and need a driveshaft loop & helmet at the very least.
PS... thanks for not laughing at my reaction time guys, that was terrible!
« Reply #4 on: October 09, 2013 - 04:25:04 PM »
Way to go Jeff!    :burnout:
Offline Oldschool
  • Member Since 9-05-06
« Reply #5 on: October 09, 2013 - 05:06:25 PM »
Nice!  It's always a blast to take 'em down the track.....    :burnout:
Ken  --  In Georgia
Offline mr_340
« Reply #6 on: October 12, 2013 - 10:19:09 AM »
Good times for a First time out. :thumbsup:
With that MPH you should be able to get into the high 11's with some traction :clapping:  what gear are you running?
« Last Edit: October 12, 2013 - 09:03:41 PM by mr_340 »
Offline Sleepychallenger
« Reply #7 on: October 12, 2013 - 10:23:53 AM »
What was in the other lane
Offline nqkjw
« Reply #8 on: October 12, 2013 - 07:13:25 PM »
Agreed.
Traction will pull your mph back to 112 which gives you a potential 11.8 seconds.
Edit: actually after re-reading your timecard your 60fts show 1.9 whereas you should be around 1.6 which means with traction you'll pick up abt 0.3 on your 60ft which will mean abt 0.45 off your ET.
So there's still half a second or so missing.Maybe a bit slow on the gear changes or less than ideal rear gear?
« Last Edit: October 12, 2013 - 07:29:38 PM by nqkjw »
Burnouts are cool but Traction is the Action
« Reply #9 on: October 13, 2013 - 10:44:26 PM »
So now you need this b body dana 60 I have here  :grinyes:  Some sticky tires, caltracs and a good clutch. Then hang on for the thrill. Your bitten now.   :burnout:
Offline nqkjw
« Reply #10 on: October 14, 2013 - 04:19:14 AM »
Haha...you're dead right Moparal. It can get very addictive :2thumbs:
« Reply #11 on: October 19, 2013 - 10:33:30 AM »
Yeah, I have a bit of the fever now  :droolingbounce:
The immediate thoughts are of tightening the car up & getting some traction.
This past year we had some disappointing experiences at a couple of car shows, so hitting the track has been a fun alternative.
My rear gears are 3:55, and yeah I was probably a little less than perfect on the gear changes.
It's getting cold here now and the local tracks are wrapping up this weekend.... time to get the garage heater out & start wrenching!
« Reply #12 on: October 19, 2013 - 10:35:12 AM »
If memory serves correctly, I think it was a Ford Focus!
« Reply #13 on: November 01, 2013 - 01:36:29 AM »
I am glad you are still having fun with it , try some nitto drag radials ,clamp the front 1/2 of the leaf springs or add some 1/2 leafs & clamp it
Offline StRoKeR
« Reply #14 on: January 17, 2014 - 02:51:39 PM »
 The better my 60ft is the more mph I get. I run MT street radials. Lots left in you car for sure.
Member Since January 14, 2004
71' Dart - 9 second All Motor Pump Gas Street Car! Full Interior, Full Exhaust, Raced on Local 93! 3400lbs.
72' Challenger - 10.67 @ 127.78 All Motor on 93 pump gas! 3850lb street car (SOLD)
