...and motor mounts, and trans mount, and verifying mounting pad dimensions, and...
Center link interference is usually the stack up of tolerances from all of the items listed above. Add into that factory assembly tolerances, which at some points is as loose a .125", and you have a formula for interference. Hence the factory recommendations for shimming and grinding/welding.
