Author Topic: shift lever  (Read 3701 times)
Offline dutch
Re: shift lever
« Reply #15 on: October 04, 2013 - 12:14:40 AM »
just think out loud here,
 not sure if it`s even possible, but if your trans has been apart, could it be the selectorshaft is not in the correct position?
what if engine and / or trans mounts are in the wrong way?  do you have a driveshaft in there?  No problems fitting any other drivetrain related parts?
*** Bart ***
Offline rattlesnake
  • Rattlesnake
Re: shift lever
« Reply #16 on: October 04, 2013 - 11:16:54 AM »
Tranny was rebuilt by a mopar technician who came highly recommended especially for trannies. (But we have all heard that before) I am not sure if it is possible to have the lever on upside down due to there is only one flat side to the shaft, but I will definitely check it out. I did not have any problems fitting any components other than the Dougs headers were a little close on the passenger side torsion bar (1/8" close). I have the same motor mounts and tranny mounts that have always been in it and double checked they were installed correctly, just simply because I have done so many brilliant things in my 47 years.  No driveshaft yet, maybe today. I will get pics posted and let yall take a look.  :pullinghair: :swear:
keep honking I'm reloading
Offline rattlesnake
  • Rattlesnake
Re: shift lever
« Reply #17 on: October 05, 2013 - 09:20:51 PM »
Well I finally solved the mystery! After all my initial investigations, after looking at a blue jillion pictures, after talking to as many people as I could find that were willing to offer insight on shifters and how and where they are to be located in the car. After all my relentless pursuits at perfectionism I somehow located the shifter mounting bracket too far back in the car. Doing so threw off the geometry of the shifting arms and linkage causing as much havoc as possible.
After sitting through 5 softball games in two days for my 11 year daughter, and enjoying every one of them, cause I know this time only arrives once, I finally was able to spend 4 hours (from midnight until 4:00a.m.)removing the console and shifter, just to reinstall in the correct location by continuing moving it forward in the cab until all the indents hit perfectly. :woohoo: Thanks to all for the input and a special thanks to Dutch for all the pics and causing me to back up and think about the problem being bigger than the shift lever. It is fixed and working like a champ. Now on the downside I now have every chrysler made shift lever known to man and a few extra linkages and other pieces too that I might use at a later date or will have for some other lost soul. Til next time have fun.
Ray,
Offline dutch
Re: shift lever
« Reply #18 on: October 06, 2013 - 04:39:41 AM »
glad you found it  :2thumbs:
*** Bart ***
Re: shift lever
« Reply #19 on: October 06, 2013 - 07:49:28 AM »
 :2thumbs:
