Author Topic: Another cooling problem - 70 SE w/383 AT  (Read 1276 times)
Offline spamtank
« on: October 03, 2013 - 08:26:36 PM »
Car ran great all summer, even during some of the hottest days.  Now in the fall, the days/evenings are cooler, but after a 10-30 minute drive, the radiator pressure relief cap vents and splashes about 1/4 cup of anti freeze on the ground about 5 minutes after it has been shut off.
Think I have a 185 deg t'stat.  Runs just above the lower line on the temperature gauge.
Replaced the water pump end of last year, and put a radiator shroud back on.  Belts are tight.
Can't figure out what's changed.  I should probably check to see if any of the hoses are collapsing during operation.  But I don't think so, they are only a year or two old.
Any thoughts?
I suppose an air pocket some where in the cooling system could expand once the engine is turned off.  it's odd that it just started recently when the weather cooled off.
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
Re: Another cooling problem - 70 SE w/383 AT
« Reply #1 on: October 03, 2013 - 09:27:50 PM »
not air pockets but the heads could be boiling coolant after shut down so either the flow has changed or maybe just a weak rad cap
Offline jhaag
« Reply #2 on: October 03, 2013 - 11:15:44 PM »
I agree with chryco. change the radiator cap. If your operating temps are still good when driving then your symptom points to the cap. If your cooling system is in good shape You might even think about putting a little higher rated cap on. The higher rate cap will raise your boiling point a little more.
love 70 Challengers
Offline spamtank
« Reply #3 on: October 04, 2013 - 09:44:29 AM »
Good thought.  I'll pick up a new cap and try that.
2013 RT Plus 6M
Offline DocMel
« Reply #4 on: October 04, 2013 - 07:06:08 PM »
If its a stock radiator (40 plus years old) and the above doesnt solve it, remove it and have it cleaned/recored at your local rad shop
Offline spamtank
« Reply #5 on: October 04, 2013 - 07:39:25 PM »
Thanks for the idea.  Radiator has been replaced, and is in pretty good shape.  But probably worth cleaning it out.
2013 RT Plus 6M
Offline spamtank
« Reply #6 on: October 08, 2013 - 10:03:32 PM »
So I replaced the cap, and that seems to have fixed the problem.    :bananasmi Should have thought about that one a while ago.  :2thumbs:
I usually start a repair job by replacing the most expensive or hard to work on part first.   :horse:
Thanks guys!
2013 RT Plus 6M
« Reply #7 on: October 08, 2013 - 10:40:21 PM »
So I'm not the only one eh?
