Author Topic: Stupid coil question  (Read 712 times)
Offline Fern
« on: October 05, 2013 - 01:35:56 PM »
How do you tell which side of the coil is negative?
Trying to hook up an aftermarket tach.
Offline blown motor
Re: Stupid coil question
« Reply #1 on: October 05, 2013 - 03:19:25 PM »
There are no stupid questions here. Someone will chime in with the answer. I don't know either.
« Reply #2 on: October 05, 2013 - 03:41:43 PM »
The one on my car now, & I think all of the stock style, have a + or - molded in the top next to each terminal
Offline RzeroB
  • In The Lou and looking for a new (old) ride
« Reply #3 on: October 05, 2013 - 03:45:41 PM »
 :iagree: And if it doesn't, follow the leads coming off of the coil. The "negative" lead connects to the distributor and the "positive" will connect to the ballast resistor. If the wires disappear into a wiring harness you could always check the terminals with a multimeter or probe light to see which terminal has power when with the ignition key in the run position to identify the positive terminal.
« Last Edit: October 05, 2013 - 03:48:15 PM by RzeroB »
Cheers!
Tom
St Louis, MO
Former owner of 16 classic Mopars. "It is better to have owned (Mopars) and lost then to have never owned at all" (apologies to Alfred Lord Tennyson)
Offline Fern
« Reply #4 on: October 05, 2013 - 03:57:51 PM »
Thank you  :2thumbs:
« Reply #5 on: October 06, 2013 - 06:53:09 AM »
You haven't seen some of my questions then.. :o
I agree with bullitt, Ive never seen a coil without the polarity identified by one or both of the primary terminals.
