Author Topic: Steering shaft Measurement needed  (Read 1309 times)
« on: October 06, 2013 - 12:39:48 AM »
Can anyone give me the measurement from steering column housing end to end tip?
Thanks
Re: Steering shaft Measurement needed
« Reply #1 on: October 06, 2013 - 07:46:58 AM »
Power or manual ?
« Reply #2 on: October 06, 2013 - 10:59:32 AM »
Power steering.
thanks
« Reply #3 on: October 13, 2013 - 07:16:20 PM »
Can anyone give me the length from the end of column tube to end of splined connector?
I can estimate from there what the shaft length is.
The reasone why I'm asking is that when I re built my steering column, it collapsed in so I need to get the right length back out to where it was originally.
Offline 72cudamaan
« Reply #4 on: October 13, 2013 - 08:02:33 PM »
Thanks
Mike, mine measures 10 3/4".
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #5 on: October 13, 2013 - 08:14:06 PM »
Mike my car is all together so I can't measure exactly what you're asking. It's a '73 Challenger with P/S if that makes a difference.
From the plastic piece at the bottom of the outer tube (don't see this in your picture) to the top of the coupler is 9" & to the end of the coupler is 12"
« Reply #6 on: October 13, 2013 - 08:39:41 PM »
Perfect!
Thanks Wade.
A little bit of measuring on mine, and I should be able to adjust it to that.
« Reply #7 on: October 13, 2013 - 08:44:51 PM »
Thanks Andy.
This brings up an interesting possibility.
Was that from end of column to end of coupler?
Are Challenger lengths different than Cuda's that had P/S?
Offline 72cudamaan
« Reply #8 on: October 13, 2013 - 10:36:08 PM »
Thanks Andy.
That was from the end of the tube to the end of the shaft, just as you had marked with red arrows.
Offline 72cudamaan
« Reply #9 on: October 13, 2013 - 10:37:51 PM »
And I believe the steering columns interchange within e-bodies.
« Reply #10 on: October 13, 2013 - 10:41:15 PM »
 :2thumbs:
