Author Topic: How about a Fluid Damper for an externally balanced 340 crank???  (Read 584 times)
Offline cudaracer
« on: October 09, 2013 - 11:46:29 AM »
My 73 340 crank is cast and needs a front damper.  Someone suggest the best is fluid. Will that be OK with an externally balanced lower end?
Offline cudaracer
Re: How about a Fluid Damper for an externally balanced 340 crank???
« Reply #1 on: October 09, 2013 - 12:30:36 PM »
Forgot to ask,
does the flex plate, ring and torque converter match up to a cast crank 340 differently than an internally balanced one?
« Reply #2 on: October 09, 2013 - 10:50:56 PM »
I believe some companies offer a fluid damper with a weight for external balance but a neutral balanced one is no good on a external balanced engine . The same Flex plate can be used with a specially balanced converter or you can use a neutral balance converter with a special balanced flex plate , either conbo will bolt up work for you .
Offline cudaracer
« Reply #3 on: October 10, 2013 - 07:58:18 AM »
thanks
