Author Topic: Need rim backspacing and offset help  (Read 3970 times)
Offline dave73chally
« on: October 12, 2013 - 11:46:16 AM »
Upgrading to 15", looking at 15x7, 4" backspacing, 0 offset. 15x8, 4" backspacing, -12.00mm offset. Planning to run 235/60 front and 275/60 back. I know ideal backspace is 4.5" but having trouble finding cragars in that spacing. Will this fit without any issues? I have a stock 73 challenger with 15" rallyes at the moment.
73 Challenger
Offline Strawdawg
    • Vortex Buicks
Re: Need rim backspacing and offset help
« Reply #1 on: October 12, 2013 - 04:22:27 PM »
on a 7" wheel, 4.0" back spacing shouild position it the same as 4.5" on an 8" wheel.  7" on a 275/60 is a bit narrow for the tire
« Reply #2 on: October 12, 2013 - 05:35:53 PM »
Thanks for the reply. What if I went 4.25"bs on 7" front and 4.75"bs on 8" rear. Want cragar soft 8's and they don't have a 4.5"bs available.
73 Challenger
Offline nqkjw
« Reply #3 on: October 12, 2013 - 07:04:34 PM »
4.75BS on 8"rim should be perfect.
I've got 4.5BS on 8"rim and had to centre the diff,trim the guard lip a little and machined 2mm off the axle face of the rim to get them to fit nice.
I'm using a 275/60/15 tyre.
Burnouts are cool but Traction is the Action
Offline Cuda54
« Reply #4 on: October 15, 2013 - 06:42:47 PM »
I am running 275/60/15 on a 8" wide Cragar SS 15" with a 5" back space on the back end of my 72 Cuda. I have smaller tires on the same rims up front.
« Reply #5 on: October 18, 2013 - 08:03:39 AM »
Changed my take on this. Going with  15" cop wheels from Wheel Vintiques. Fronts are 15x7 with 4" backspacing, rears are 15x7 with 4.5" backspacing. Planning to run 235/60 up front and 275/60 out back. This seems like a very common combo but I've read mixed reviews about issues, some have none while others need to trim? Read through the 45+ page tire combo thread but just want to be certain.
Any feedback would be great, planning to place my order today.
73 Challenger
« Reply #6 on: October 18, 2013 - 11:08:14 AM »
Should be good other than the 7" wide rim is kinda small for a 275 tire.  :2cents: IMO, you should go with an 8" rear wheel.
« Reply #7 on: October 18, 2013 - 11:54:48 AM »
My mistake, the rear is a 15x8 with 4.5" backspacing. nqkjw (above) is running the same on the back of his and had fitment issues, is this common? I've seen a ton of posts with this setup on stock suspensions, but have also seen posters with issues?
« Last Edit: October 18, 2013 - 11:56:48 AM by dave73chally »
73 Challenger
Offline Chlngrcrzy
« Reply #8 on: October 18, 2013 - 04:17:21 PM »
 :popcorn:
Offline Aracer
« Reply #9 on: November 03, 2013 - 01:49:36 AM »
I run 275/60-15" on 10" wide Billit Sp. 8 hole (5.5"Bs.) Mags,       I have the 1968 housing with DrDiff 1" offset hangars.     Car is a 1974 cuda.        It has +2" rear leafs and .90 stock HD bars.            I just ordered 235/70-15" on the 8" Billits / 4.5 Bs. for the front.        At 27.9" tall in front and 28.3" on the rear.        I hated the way the car handled with 26" tires on the front, it was too much difference and wiggled when pushed in tight turns.        So, in addition I will get more roll out at the starting line, and will get some room to bump the light for some overhang. It adds up at the finish line, to a foot.
Offline nqkjw
« Reply #10 on: November 20, 2013 - 04:46:47 AM »
I think it's to do with how square the car was originally assembled.
Some have no dramas.
I know with mine nothing is square even though I know it's never had a repair and was in original paint when I got it.
Just manufacturing tolerances I believe.
mine must have been a Friday car :clueless:
« Reply #11 on: November 21, 2013 - 04:57:43 PM »
Mounting my 15x8-4.5" rear and 15x7-4" wheel vintiques front this weekend. I'll let you guys know how it turns out and post some pics  :thumbsup:
73 Challenger
Offline ToxicWolf
« Reply #12 on: November 21, 2013 - 06:48:28 PM »
I just put on the same size wheels and tires except I put 255s on the rear instead of 275s on my 70 Challenger. Will be watching to see how it works out.   :popcorn:
Offline crash520
« Reply #13 on: November 21, 2013 - 08:10:54 PM »
Has,
anyone been able to fit 295's on a 10" rim under a 73 Cuda with not moving the springs inboard or trimming the fender lip???
Offline Dusty1
  • Revived
« Reply #14 on: November 22, 2013 - 05:03:53 PM »
295/50/15 on 8.5 wheels---- no modification.
Garys 1972 BS
