Author Topic: How many engines were available for 1970? 8 or 9?  (Read 4152 times)
Offline Sleepychallenger
Re: How many engines were available for 1970? 8 or 9?
« Reply #15 on: October 20, 2013 - 07:30:45 AM »
My 383 Magnum came factory with a carter I thought the difference was the cam
Offline EB3-GranCoupe
  • BP23 U0B
« Reply #16 on: October 21, 2013 - 12:08:50 PM »
I don't believe that the carb made a difference, holley or carter. I've seen them both on N-code cars; that was just a supply issue.  The specs of the cam is what makes the difference.
Offline cjm
  • 70 Cuda - In Progress.....
« Reply #17 on: October 23, 2013 - 12:01:24 PM »
Yes, the cam was different, but there was also a change in the heads. The 906 heads (which were used on 440's as well) were "upgraded" with stiffer valve springs and had dampers. But I do believe that all of the 383 engine that came with Holley's were rated at 335 HP (5200 rpm) (there could be some with Carters).......... Notice the list below had the 69 383 (Carter) at 335hp 5200rpm (10-1 cr), the 70 383 with the Holley 335hp 5200 (9.5-1).......  and you had to have dual exhaust.......
The 300hp ratings were at 5000rpm.....      then again, a lot of people will say the engines were "underated" for insurance purposes....
1968-1969
4-bbl
330@5000 rpm
425@3200 rpm
10:1
1968-1969
4-bbl (Carter AVS)
335@5200 rpm
425@3400 rpm
10:1
1970
2-bbl
290@4400 rpm
n/a
8.7:1
1970
4-bbl
330@5000 rpm
425@3200 rpm
9.5:1
1970
4-bbl (Holley)
335@5200 rpm
425@3400 rpm
9.5:1
1971
2-bbl
275@4400 rpm
375@2800 rpm
8.5:1
1971
4-bbl
300 rpm
410@3400 rpm
8.5:1
« Last Edit: October 23, 2013 - 01:39:33 PM by cjm »
