Author Topic: Where should i locate my MSD 6A  (Read 2938 times)
Offline Chlngrcrzy
« on: October 19, 2013 - 09:56:52 PM »
This things is big. Where do you install it? Firewall? Fender?
Re: Where should i locate my MSD 6A
« Reply #1 on: October 19, 2013 - 10:13:30 PM »
Cooler is better , in front of the radiator fire wall or beside the rad
Offline cudabob496
« Reply #2 on: October 20, 2013 - 01:00:27 AM »
Mine is under the dash, inside the car, on pass side. Nice and cool there. I put as much engine bay
electrical stuff on firewall under dash as possible, like starter solenoid, volt reg, etc. I did remove
the heater box, so there is more room. And without heater box, cold air blows right on electronics, from
the cowl intake.
« Last Edit: October 21, 2013 - 06:52:10 AM by cudabob496 »
2011 Kawasaki Z1000
« Reply #3 on: October 20, 2013 - 06:28:53 AM »
Mine is in the stock ecu location, but under the battery tray is where it is likely to end up this winter.
« Reply #4 on: October 20, 2013 - 08:06:01 AM »
Mine is under the battery tray..... somewhat hidden?
Offline Chlngrcrzy
« Reply #5 on: October 20, 2013 - 11:09:40 AM »
Thanks for the ideas. Any pictures?
« Reply #6 on: October 20, 2013 - 12:39:24 PM »
I would mount it in front of the rad wall behind the left headlight area
« Reply #7 on: October 20, 2013 - 03:16:28 PM »
Would the length of the wires from the dist to the msd be a problem with the msd in the battery area?
Offline 67vertman
  • Member since 9-23-2005
« Reply #8 on: October 20, 2013 - 08:44:47 PM »
Nope,  I mounted mine under the dash on the driveside.  One year in, no issues,
« Reply #9 on: October 20, 2013 - 09:06:26 PM »
I have run the wires all the way around the engine compartment so about 8' with no issues
Offline cudabob496
« Reply #10 on: October 21, 2013 - 12:28:17 AM »
Ya, I think electricity is supposed to travel near the speed of light.  Extra wire length will just give you
a tad more electrical resistance, and more opportunity for electrical interference, but should not be a problem
for those wires.
« Last Edit: October 21, 2013 - 03:33:41 AM by cudabob496 »
2011 Kawasaki Z1000
Offline HP_Cuda
  • Mopar or No Car!
« Reply #11 on: October 21, 2013 - 11:31:01 AM »
let's see pics of all those locations.
I'm about to locate mine and I was thinking of firewall (yeah I know like everyone else) or under the battery tray but heck the cooler the better!
Offline Bart
« Reply #12 on: October 21, 2013 - 11:42:50 AM »
Mine is in the glove box
1970 Cuda 383
2008 Titan
2010 G37s
1996 Advantage Victory 27 502ci
2013 HD Roadking
Offline 67vertman
« Reply #13 on: October 21, 2013 - 10:17:46 PM »
 :banghead: I wish I would have taken pictures when I put mine in.  I will take some this weekend though.
Offline Kapteenikosmos
« Reply #14 on: October 23, 2013 - 07:54:21 AM »
I have my MSD streetfire box in the trunk. I used to have a summit racing CDI box at the passenger floor under the heater box the but the buzzing noise made me crazy and my wife was complaining that it made difficult to keep her legs comfortably. I used high quality wires to lenghten the wires for the MSD and mounted the box to the trunk lid support. I routed the wires quite carefully so that the wires that have "bang" going on are away from the feed cables and so on. Zero problems so far. If you have the battery in the trunk as I have then I would say that the trunk is the best place to have the box if you want a clean installation in a dry and cool location. Also accessing the rev limiter dial is more than easy.
I will take a pic tonight and post it here.
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
