Author Topic: Meziere 55 gpm with housing  (Read 1620 times)
Offline KingCuda440
« on: October 20, 2013 - 05:54:56 AM »
Has anyone used the 55 gpm Meziere Electric Water Pump (wp306)?  It's for a big block and it includes the water pump housing. I'm curious how you mount your alternator bracket with this housing. Thanks for any advice you offer.
Re: Meziere 55 gpm with housing
« Reply #1 on: October 20, 2013 - 08:51:56 AM »
Yes I have used one , I don't have pix but we had to modify brackets to mount the alt in line with the crank pulley & have enough swing to tighten the belt , not much help I know
Offline StRoKeR
« Reply #2 on: October 20, 2013 - 09:57:45 AM »
CVR make a 55gpm drop in setup for the mopar water pump.
Member Since January 14, 2004
71' Dart - 9 second All Motor Pump Gas Street Car! Full Interior, Full Exhaust, Raced on Local 93! 3400lbs.
72' Challenger - 10.67 @ 127.78 All Motor on 93 pump gas! 3850lb street car (SOLD)
Offline KingCuda440
« Reply #3 on: October 20, 2013 - 11:17:39 AM »
Thanks for the help.  I was going to purchase the 45 gpm but Meziere doesn't recommend for high compression street car. I have 12.5:1 Ross pistons. I will look into the CVR.
Offline KingCuda440
« Reply #4 on: October 20, 2013 - 12:28:57 PM »
Has anyone used the CVR pump on a street car?  If so, has it been dependable?
Offline cudabob496
« Reply #5 on: October 21, 2013 - 12:41:32 AM »
I used the 45 gpm Meziere on my 496 street engine. It could not support cooling in the summer. Went back to
Mopar aluminum housing and mechanical pump.
2011 Kawasaki Z1000
Offline KingCuda440
« Reply #6 on: October 21, 2013 - 05:25:08 AM »
I'm going to go with the Meziere 55 gpm. I think the housing would have to flow better than the stock one. Chryco Psycho does it have a provision for a temp gauge?
Offline KingCuda440
« Reply #7 on: October 21, 2013 - 05:26:19 AM »
Thanks for the input cudabob496.
Offline cudabob496
« Reply #8 on: October 21, 2013 - 06:50:38 AM »
You're welcome. In the summer, I was doing some street activities, running between stop lights about 1/2 mile apart.  I was taking it up to
6000 rpm on a run, and if I got caught at a stop light, the electric could not handle the heat that had been generated from the run. It was about
90 out, and I even have an alum radiator.  with an mechanical pump, you are getting much more than 45 gpm I think, because you got your engine at 6000 rpm.
Plus, you are dumping a lot of heat into those aluminum heads.  In cooler weather, the electric did better.  And one time, I blew a fuse for the electric pump, and I had instant steam blowing out of my radiator overflow bottle! Temp zoomed past 230. Immediately shut it off, but was in highway traffic, and barely made it to the side of the road!
After that, went back to mechanical. heck with saving 3 hp!!!!
2011 Kawasaki Z1000
Offline BS CUDA
« Reply #9 on: October 21, 2013 - 10:03:18 PM »
 I ran a Meziere for a week or two and couldn't keep her cool as I like. Back to mechanical and back to cool.
« Reply #10 on: October 22, 2013 - 01:03:08 AM »
Always go with the 55gph mez. You won't look back.  The 100 series is for toys n boys.
