At the front of the door, there will be a small screw or bolt that holds the trim in place -- it threads into a clip within the stainless steel.
At the rear edge of the door, there should be a (3/8" IIRC) nut holding the rearmost trim clip.
The remaining clips should simply be the press-in style, and can be removed by working the moulding gently upwards.
Since it appears that you have the door off, just look in past the glass to make sure that no-one has used bolt-in clips. And working them loose from the bottom is never a bad idea
