Author Topic: How do my plugs look  (Read 640 times)
Offline ff6849
« on: October 20, 2013 - 02:41:44 PM »
This is what my plugs look like after 1000 miles of running over the past 8-10 months, is this what they should like the car runs like a top starts right up, had some pinging issues during the hottest part of the summer (110' welcome to desert southwest) with the A/C running, added a little racing gas and the pinging when away. Back to running 91 octane and no problems. Just trying to fine tune and dial in the car.
440 with 915 heads
tti headers
comp xe274h cam
750 eddy
hollry SD intake
msd igntion
« Last Edit: October 20, 2013 - 05:19:17 PM by ff6849 »
(__________]]]]]}~~~~
73 440 Cuda'
915 heads (mild head work, stock bottom end 10/9:1 compression)
A518 2600-2800 Stall
4.10 rear gear
TTI headers with 3' exhaust with  X pipe
comp XE274H cam
Hughes Roller Rockers
Holley Sniper EFI
Holley Street Dominator intake
MSD ignition
Re: How do my plugs look
« Reply #1 on: October 20, 2013 - 08:57:46 PM »
Looks OK to me , tan center & not overly black on the top of the threads , How is it running ?
Offline ff6849
« Reply #2 on: October 21, 2013 - 12:29:21 AM »
I just finished the car February, its been running great and starts right up, had some minior issues This is my first build so I am a little worried about everything I did most of the work myself with a lot help from friends, and a lot help from board. Just wanted to pull some plugs to make sure everything was working as it should, looks as if it is. So I can start  worrying about some other fictitious problems.
73 440 Cuda'
4.10 rear gear
comp XE274H cam
Holley Sniper EFI
MSD ignition
Offline cudabob496
« Reply #3 on: October 21, 2013 - 12:33:04 AM »
Look a tad rich to me, but maybe put in some new ones to verify, since these supported
a new engine break-in. Rings gotta seal, and all that cam lube, etc.
« Last Edit: October 21, 2013 - 06:53:24 AM by cudabob496 »
2011 Kawasaki Z1000
Offline anlauto
« Reply #4 on: October 21, 2013 - 08:36:28 AM »
How do my plugs look ?
Offline cudabob496
« Reply #5 on: October 21, 2013 - 11:29:46 PM »
I'd say they are mis-firing!
2011 Kawasaki Z1000
