Author Topic: Challenger door trim insert make over  (Read 3788 times)
Offline AU6pack
« on: October 21, 2013 - 07:04:12 AM »
A lot of Challengers I've seen have been let down by the old looking door trim inserts and mine is no exception.
Anyone got any tips on how to get these looking good? I have new woodgrain vinyl decals to replace the old ones and was thinking of re-chroming the insert. But how do you get the new woodgrain to go perfectly over the pentastar?
I assume that when they were made the woodgrain went on first then the pentastar emblem was inserted last giving a perfect border as the emblem sits over the woodgrain, its not cut around it.
Any suggestions, tips, pics?
Craig
Melbourne, Australia
1970 Challenger 416 6 pak
Resto thread - http://www.cuda-challenger.com/cc/index.php?topic=114787.0
Offline Katfish
  • 70 Challenger
Re: Challenger door trim insert make over
« Reply #1 on: October 21, 2013 - 07:58:59 AM »
I did CF overlay on mine.  You need to gently grind the pins enough to get the pentastar out.
After installing the new overlay, just push the emblem back in and add a dab of epoxy on the back to hold it.
Offline anlauto
« Reply #2 on: October 21, 2013 - 08:34:17 AM »
Looks great :2thumbs: except it's not a "pentastar" it's a "Fratzog"  :2cents:
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #3 on: October 21, 2013 - 01:01:49 PM »
From Moparts: http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Board=A12&Number=7767546
I recently did mine. I had 2 pairs with the Triad emblems. I selected the 2 best (out of the 4), removed the Triad emblems by grinding down the peened/swaged post on the backside of the insert; then pushed out the emblems; then I removed the original woodgrain; then stripped the black satin paint, and cleaned everything THOROUGHLY with alcohol; then masked the entire front side (3M Blue Tape); then used an exacto knife to remove the tape within the channel that will be painted satin black (rattle can); after painting and BEFORE removing the tape, I used the exacto knife again (I learned this was necessary after the first attempt without using the knife); then applied the new woodgrain decal (I tried PCG decals, but was not happy). I then bought and used DetroitMuscleTechnologies (DMT) decals, and IMO they are superior and the best on the market; then reinstalled the Triad emblems, and dabbed a little JB Weld on each of the post, let cure, then grind smooth. Came out excellent. BTW - I also used DMT's decal for my 4-SPD console plate. I tried the others, but was not happy with the end result. The DMT stuff is the BEST.  If you don't already have the DMT woodgrain decals, I would strongly suggest getting them.  The others are not as good and you'll be disappointed as I was with the results.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline AU6pack
« Reply #4 on: October 22, 2013 - 01:45:29 AM »
Thanks for the correction  :bigsmile:
Craig
Offline AU6pack
« Reply #5 on: October 22, 2013 - 01:48:07 AM »
Great tips - Thanks a bunch. The Carbon ones look good... got me thinking!
Katfish - Can you post a pic of the carbon dash bezel?
Craig
Offline Katfish
  • 70 Challenger
« Reply #6 on: October 22, 2013 - 06:26:48 AM »
I've painted the shifter knob black since these pics.
Offline Cuda416
« Reply #7 on: October 22, 2013 - 06:47:19 AM »
I'm diggin it, a lot!  Nice job lining up the pattern on the bezel!
-C
70' Barracuda conv. (project)
Offline AU6pack
« Reply #8 on: October 22, 2013 - 07:22:22 AM »
Got any tips on how to remove the  ^&%#@! original woodgrain? Its stuck on so good I reckon I'll bend the panels scraping it off!
Craig
Offline AU6pack
« Reply #9 on: October 22, 2013 - 07:24:45 AM »
Thanks Katfish - I'm definitely going carbon over woodgrain as you have done. I've got a carbon pistol grip for the new 5 speed that will match it all up perfectly. Thanks for the idea  :2thumbs:
Craig
Offline blown motor
« Reply #10 on: October 22, 2013 - 08:36:09 AM »
What's the yellow button in the console storage box for?
Offline Katfish
  • 70 Challenger
« Reply #11 on: October 22, 2013 - 09:27:55 AM »
Good eye, that's a life saver.
One of the best things I've added to the car, electric trunk opener, haha :)
Offline filmsurgeon
« Reply #12 on: October 22, 2013 - 01:52:50 PM »
I'm told a heat gun works well to soften the old, dried adhesive, but I didn't end up using one.  I used a razor blade scraper patiently and carefully.  First, get under the woodgrain, then wiggle the blade slowly while pushing it in a forward direction.  After the old woodgrain is removed, use an adhesive remover to get off what was left.
Offline jhaag
« Reply #13 on: October 22, 2013 - 03:59:10 PM »
I used spray on paint remover on the dash bezel. I think it was permatex from NAPA. spray it on, let it set until it bubbles, wipe it off. Very easy and leaves a nice clean surface.
love 70 Challengers
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #14 on: October 22, 2013 - 08:04:10 PM »
Hey katfish, any chance u could out up some more pics of ur car?  The more I see of it the more similarities I see with my build!   :bigsmile:  would love to see more pics of the car!  Thanks man!
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
