Author Topic: Driver side quarter replacement - 73 cuda  (Read 833 times)
Offline redo1973
« on: October 21, 2013 - 09:56:35 PM »
Getting brave and gaining confidence. I removed the driver side quarter that had been pieced together with braze.  I knew that I had an issue with the B pillar before I started.  I've noticed the issue with other cars at shows with bubbling paint so I'm thinking that it is not unique but not seen anyone post on the repair.  I need to fix the angled support piece connected within the window frame.  I do not see it on AMD site.  It'll be a challenging removal. Ha anyone seen this part or if not I think that I can fabricate something if necessary.  Any ideas?
Re: Driver side quarter replacement - 73 cuda
« Reply #1 on: October 21, 2013 - 10:06:15 PM »
There was a memeber here recently parting out a Cuda.
http://www.cuda-challenger.com/cc/index.php?topic=95476.0
Offline Edison1970
« Reply #2 on: October 21, 2013 - 10:22:44 PM »
You are going to have to cut the roof back a little more.  Mine was rusty up another 6 inches.  If it doesn't go any farther, you can just cut some steel patches and weld them in.  You can look at mine in the members restoration under 72 cuda resurrection.
Offline redo1973
« Reply #3 on: October 21, 2013 - 10:38:59 PM »
Thanks guys.  Mine definitely goes up about six inches based on what I can see through the window frame (I think you can see it in one picture).  It looks like there is a seam within the window and looks like one piece.  I really don't want to cut the roof, still paying for the other metal purchased. :bigsmile: What was it you did to access the metal?  I was thinking that I could cut and remove without cutting into the roof skin.
Offline Edison1970
« Reply #4 on: October 21, 2013 - 11:40:16 PM »
You'll have to cut into the roof.  I didn't worry about it since that area from the factory had lead filled in anyway.  Extending the filler another six inches is not bad.  I cut a piece of sheet metal and bent it to the contour of the roof.
Offline redo1973
« Reply #5 on: October 22, 2013 - 07:13:37 PM »
Did you have to remove the drip edge as well or cut around it?  I'm planning to remove the entire piece because of the rust hole spots.
Offline Edison1970
« Reply #6 on: October 22, 2013 - 08:51:35 PM »
I had to repair mine.  It had a rust hole in it. It wasn't that hard.  Just time consuming.
Offline redo1973
« Reply #7 on: October 22, 2013 - 09:15:43 PM »
I just spent 30 minutes going through your project log.  Very Impressive and motivating!! I have many of the same issues you had and lots of questions as a new welder also.  Metal preparation has also been a mixed bag; dipping, sand blast, stripping?  I like your approach due to the stages of restoration effort.  I'll have to start a log. Thanks.
