Author Topic: Rear-end swap - 70 to 73  (Read 1093 times)
Offline redo1973
« on: October 21, 2013 - 10:30:16 PM »
I have a base model 73 Barracuda that I am upgrading to a Cuda level.  The original car has a 8 3/4 axle with 2.76 gearing.  I have access to a 1970 8 3/4 axle with 3,23 gearing.   We calculated motor set-ups for other ratios and picked the 3.23 for decent highway and quick starts.  I need to make measurements but thought that I would ask opinion on this swap; will it fit and function?
Offline Katfish
  • 70 Challenger
Re: Rear-end swap - 70 to 73
« Reply #1 on: October 22, 2013 - 12:10:29 AM »
If it's from another e-body, it's a drop in, will fit perfectly.  70-74 all have the same dimensions.
« Reply #2 on: October 22, 2013 - 01:00:35 AM »
Your emergency brake lines are dif from 70 to 73. Just install the 323 chunk . It will take a couple of hours and be a lot less envolved.  If wanting the 70, keep your backing plates on that is with your car now
« Reply #3 on: October 22, 2013 - 07:49:14 AM »
if you are going to pull the axles to swap the gears it is easier to swap the backing plates at that point , also a 70 E body diff is the same dimensions as the 73 , if the diff is from anything else it is not .
Offline redo1973
« Reply #4 on: October 22, 2013 - 07:09:26 PM »
Thanks everyone.  The rear end is from a 70 Chally,is a sure grip and looks good.  I thought of just pulling the center but figured keeping the rear-end complete would be better. The guy won't break it up so I have to buy all or nothing. I'm still learning the terms so what is the problem with the e-brake lines and backing plates? I should replace the 70 with the 73 if keeping the full rear-end?
When you say install the chunk is that the entire assembly with casing or just the gear assembly?
Offline anlauto
« Reply #5 on: October 22, 2013 - 07:21:56 PM »
The complete rear end as an assembly will bolt right in. As mentioned, you will have to keep your 73 E Brake cables but the will install in the 70 rear end with no issues.
You'll need to check the driveshaft U joint yoke width, there are two sizes "big" and "small" if they are not the same you will need a new rear U Joint that will adapt to the two different sizes. (any local parts store can get it)
« Reply #6 on: October 22, 2013 - 07:39:33 PM »
They used a different E brake system in 70 so you can just swap the cables or the backing plates if the brakes are the same size , the cables are easy to swap out .
Chunk is the center cast gearset , I call it the carrier or third member .
The U joint is the other variable as mentioned .
Offline anlauto
« Reply #7 on: October 22, 2013 - 07:42:39 PM »
If you want to swap the backing plates, you're getting into pulling axles, replacing gaskets etc....I get the impression that he doesn't want to "service" his rear end. :dunno:
« Reply #8 on: October 22, 2013 - 07:49:58 PM »
Exactly  :2thumbs:
Offline redo1973
« Reply #9 on: October 22, 2013 - 08:14:35 PM »
Thanks.  I get what you're talking about.  I'm doing a full restoration but haven't decided how far to tear down the rear-end.  The motor is done and transmission is yet to be rebuilt.  He wants $700 for the rear-end and I can pick it up.  I don't know the mileage but expect it to be under 60k. Does it sound like a good price or should I simply look for a chunk?  I've seen chunks at car shows but I'll probably have to have it shipped.
As a side note, do you have an idea what an 833 is worth? Is it difficult to convert from an automatic set-up?
Offline anlauto
« Reply #10 on: October 22, 2013 - 08:38:58 PM »
Seriously .... $700 ?????
I have a complete rear end out of a 1970 Cuda, e brake cables and all, listed on KiJiJi for $150 and nobody wants it.... :dunno: http://toronto.kijiji.ca/c-cars-vehicles-auto-parts-tires-other-parts-accessories-1970-74-Cuda-Challenger-Rear-Axle-Mopar-W0QQAdIdZ526476382
Having a 3:23 sure grip doesn't add THAT much value....I would expect to pay $300-$400 tops for a used rear assembly unless he has bills to prove that it's 100% restored brand new with all new bearings and seals etc....
E Body 8 3/4 are a dime a dozen..........$700 is nuts  :screwy:
Spend your $700 on a brand new center section :2cents:
I also have a 4 spd tranny listed for $450
« Last Edit: October 22, 2013 - 09:42:11 PM by anlauto »
Offline Katfish
  • 70 Challenger
« Reply #11 on: October 22, 2013 - 08:55:18 PM »
Too bad you're not closer, I have a complete e-body with 11" backing plates & 3.55's and the perches already moved in 1" for Dr Diff relocation I'm looking to get $400 for.
Offline redo1973
« Reply #12 on: October 22, 2013 - 09:24:52 PM »
Thanks again.  You guys on this site are awesome.  You just saved me a bunch of money.  I saw rebuilt 3.23 chunks at the Columbus Nats for $450 but they are in Pennsylvania.  I'll keep looking.
« Reply #13 on: October 22, 2013 - 10:34:37 PM »
Hard to say what you are buying with used parts , I answered an ad for sure grips , I told him I would buy all 4 as long as I could check them out , they were all cone type & all worn to the point the cones were bottomed out inside the case / junk
 Gearsets typically sell for $400 & up & you can bet the sure grip is beat , you could install new gears & brgs in what you have for around $450 .
 $ spd conversions get expensive , buying all the parts you can easily hit $3500 or more but buying parts smart / used you can save a lot of that cost but the trans is $00 , a new clutch can run that much as well , don't use a used one [my clutch & flywheel was $1100] , the belhousing can be $400 for a good one  & you still need a lot of other parts .
