Author Topic: Painless wiring - '73 Challenger  (Read 2096 times)
Offline moparmaster
« on: October 23, 2013 - 11:48:10 AM »
Trying to wire up my car without an original harness and the Painless kit does not have the original style connectors for such as the steering column, wiper motor, or any light sockets.  I can source the light sockets but what should I do for the wiper motor and steering column connections?  Cut the old connectors off and use bullet style or try to fins the correct ones on the internet?
My car is running the MSD EFI and ignition as well as electric cooling fans and vintage air.  All those connections will be custom jobs as well and that's why I went with the Painless kit.  Not really so Painless though.
Thanks!
Offline moparmaster
Re: Painless wiring - '73 Challenger
« Reply #1 on: October 23, 2013 - 11:48:57 AM »
I'm also running all AutoMeter gauges.  The factory harness would not have been much use to me.
Offline Devil
  • Forward, Together Forward
    • Ryan's Cars in Barns
« Reply #2 on: October 23, 2013 - 08:58:20 PM »
That's what I did with my Painless Mopar setup.  Cut off the old ends where I had to and put them on the new harness.  The universal Mopar one get you close to the right colors.
http://www.flickr.com/photos/hemipwr70/
http://carsinbarns.blogspot.com
71 Challenger R/T Clone
69 Charger R/T SE
70 Barracuda
74 Dart Swinger
93 RamCharger
88 Caprice Classic Brougham
Offline cudasteve72
« Reply #3 on: October 23, 2013 - 09:17:20 PM »
I am in the process of doing about the same thing.  I found a harness on here i think and used the connectors out of that for the steering column.  I sourced bulb sockets locally too but I haven't done anything with the wipers yet (don't plant to drive in the rain much so we shall see)
1972 Cuda Custom 70 clone  416 stroker 481/531 hp/
2006 Grand Cherokee SRT8 (daily)
1970 Challenger convertible 340 (Dad's)
1967 Dart gt slant six all original 40,000 miles driver but needs restoration (Brother's)
2011 Jeep Grand Cherokee (wife's)
Offline Travis72
« Reply #4 on: October 25, 2013 - 01:23:30 AM »
If the plastic connector bodies are in good shape you can reuse them and just buy new male and female Packard style terminals.  That's what I did with my Painless wiring setup (I used a universal kit).  For example here's one place to buy factory style connectors:
http://www.pcsconnectors.com/packard56.aspx
Travis
72 Cuda
Offline bdalehemi
  • Ramblin Wreck!!!!
« Reply #5 on: October 28, 2013 - 05:04:31 PM »
I have heard a many of issues with Painless Wiring.  I am bout to install a Ron Francis kit.
Offline RzeroB
  • In The Lou and looking for a new (old) ride
« Reply #6 on: October 28, 2013 - 06:36:38 PM »
When you spice in the OEM style connectors to the Painless harness try to solder and shrink wrap the connections instead of using crimp on connectors. Yeah, soldering makes it more painfull than painless, but the connections won't come lose or heat up due to increased resistance from them coming lose. Ask me how I know ...  :banghead: :pullinghair: :swear:
Cheers!
Tom
St Louis, MO
Former owner of 16 classic Mopars. "It is better to have owned (Mopars) and lost then to have never owned at all" (apologies to Alfred Lord Tennyson)
« Reply #7 on: October 28, 2013 - 06:37:27 PM »
I have done the RF kit as well , very similar to the Painless wiring
Offline highspeeddirt
« Reply #8 on: October 28, 2013 - 09:26:41 PM »
Im just finishing up my painless harness.  I actually enjoyed doing it.  I spliced, soldered,  and heat shrinked every connection. I reused plastic connectors from old harnesses,  but I didn't splice the wires.  I pulled the old connectors out of them and bought Delphi/Packard series 56 connectors. Crimped them on the wires with a pair of matco open barrel crimpers. Crimps them like factory crimps.  Then they just snap into the harness connector. I also used painless connectors for making a gauge cluster and switch panel harness.  Making it a lot easier to just plug it in and install the cluster.  They make them with several different number of pin choices.  I used the 15 pin connector on each. Also will need the open barrel crimpers for attaching the included pins. Wrapped everything up in painless power braid.  Makes it all very nice looking and protected.
Sent from my HTC One X using Tapatalk 2
Butte, MT
