Author Topic: Composite Intakes  (Read 2289 times)
Offline cudabob496
Composite Intakes
« on: October 24, 2013 - 10:49:57 PM »
I drive a 99 Trans Am, with an LS1 engine, in addition to my Cuda.  I took the Trans Am out today, ran around for a while, came back
home, parked it, lifted hood, and the plastic composite intake was cool to the touch! Amazing.  My Cuda M1 intake would fry my fingers!
We gotta get Mopar folks to make composite intakes for old school Mopars! Someone might make some money doing that!! China will
make them cheap!!
http://www.airflowresearch.com/index.php?cPath=79_81
« Last Edit: October 25, 2013 - 12:34:43 AM by cudabob496 »
2011 Kawasaki Z1000
Re: Composite Intakes
« Reply #1 on: October 24, 2013 - 11:49:45 PM »
Hmm Alum bolted to the top of an engine & heat rises , can you say heat sink !!  Blocking the heat crossovers & using spacer for the carb helps , but a composite intake would be good . I drove a car on the highway below freezing for an hour or so ,I had the air cleaner sealed to a SS hood scoop , it started to run badly  so I pulled over & popped the hood , we had the heat crossover blocked & the carb & Intake were ice cold , the fuel would not atomize !!
Offline cudabob496
« Reply #2 on: October 25, 2013 - 12:28:24 AM »
ya, got the heat riser blocked, and a phenolic spacer under carb. Heat rising, and heat
conduction from heads to intake.  Looks like a composite intake would be good
for at least 15 hp. Article says runs 30 degrees cooler, and you get a 1% to 2%
increase in hp for every 10 degrees you lower air temp into carb. That's why cold
air intakes are a good bang for the buck, but obviously, my big hot metal M1
intake manifold is reheating the air/fuel going into the heads.
Thats another reason you see guys putting ice bags on their intake manifolds
before a quarter mile race.
might be good to put a phenolic spacer between intake and heads!!!
« Last Edit: October 25, 2013 - 12:33:22 AM by cudabob496 »
2011 Kawasaki Z1000
Offline 72cudamaan
« Reply #3 on: October 25, 2013 - 09:03:57 AM »
Composite intakes have been in use for 20+ years. But not always with good results. Dorman makes a good
percentage of their profits by selling replacement intakes because the originals warp and/or crack. If someone
could keep these things stable (especially at higher hp levels) then it would be a great idea. But it aint gonna happen.
Back in the day cool cans were used to lower the air charge temp to create a denser charge. Worked great till the ice melted.   :rofl:
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #4 on: October 25, 2013 - 09:22:27 AM »
Could the LS1 seem cooler because no coolant goes through the intake?
« Last Edit: October 25, 2013 - 09:25:27 AM by Bullitt- »
Offline 72cudamaan
« Reply #5 on: October 25, 2013 - 12:34:58 PM »
Now that's thinking outside of the box. But you're right, a solid (coolant) will retain much more heat than air.
Offline cudabob496
« Reply #6 on: October 25, 2013 - 03:59:09 PM »
well, as with my M1, no coolant in the intake. Its just an intake bolted
to aluminum heads. But its like a hard plastic, and conducts little to no heat.
2011 Kawasaki Z1000
Offline cudabob496
« Reply #7 on: October 25, 2013 - 04:00:54 PM »
Looks like AFR is making them:
2011 Kawasaki Z1000
« Reply #8 on: October 25, 2013 - 07:26:40 PM »
I've held that same intake at my engine builder buddys shop. It's VERY lightweight! :drool: Cool 2 piece design too!  Curious to see how long it lasts in time with heat and fuel. UV is usually what does in plastics? Heat and time is not kind to plastics either.
Offline 72cudamaan
« Reply #9 on: October 25, 2013 - 07:50:01 PM »
Won't work so well on a Mopar though.  :smilielol:
« Reply #10 on: October 25, 2013 - 07:55:25 PM »
Same old story.... Chevys, first then Ferd and "maybe" mopar  ::)
Offline 72cudamaan
« Reply #11 on: October 25, 2013 - 08:08:02 PM »
Yep, and I think AFR is primarily a ferd parts supplier.  :stomp:   Their loss.  :smilielol:
Offline cudabob496
« Reply #12 on: October 25, 2013 - 10:07:40 PM »
maybe its more like the materials of a phenolic carb spacer.
Thanks to NASA, there's some pretty strong plastics out there.
I have a plastic 40cal semi automatic.
Below is a new polymer intake that is stronger than my stock composite intake:
http://www.summitracing.com/parts/CCA-54039/
« Last Edit: October 25, 2013 - 10:14:05 PM by cudabob496 »
2011 Kawasaki Z1000
Offline cudabob496
« Reply #13 on: October 26, 2013 - 04:10:29 AM »
I'll send an M1 aluminum intake to China, and order 100 polymer replicas.
2011 Kawasaki Z1000
Offline GreenFish
« Reply #14 on: October 26, 2013 - 08:15:48 AM »
That's pretty trick!  But AFR makes NOTHING for Mopars.  Hopefully this will catch on.
