Author Topic: Flyweel Question  (Read 953 times)
Offline cjm
  • 70 Cuda - In Progress.....
Flyweel Question
« on: October 25, 2013 - 03:23:43 PM »
I have a 72-340 that has a cast crank installed in my 70 Cuda. Is there a way to check to see if the flywheel is externally balanced while it is in the vehicle? I have the inspection cover of the bell housing off, so a portion of the flywheel is visible. I have read that externally balanced mopar flywheels have 3 holes partially drilled (in a row).. I have also read that you can convert a neutrally balanced to a externally balanced by machining the flywheel with 3 holes...... I just want to know what is in there.............          Slight vibration, but not too bad..
Re: Flyweel Question
« Reply #1 on: October 25, 2013 - 04:03:21 PM »
You are right on , you should be able to see holes on the front face of the flywheel
Offline cjm
« Reply #2 on: October 25, 2013 - 05:07:25 PM »
Thanks, I'll check it tonight....   I'm assuming that  Ma' Mopar drilled the holes as well, correct?? (IF it's externally balanced)...  (to make a nuetral balanced flywheel an externally balanced flywheel)....
« Reply #3 on: October 25, 2013 - 05:38:05 PM »
If the flywheel is properly balanced from t he factory or later on it has to have the holes  :2thumbs:
Offline cjm
« Reply #4 on: October 28, 2013 - 08:38:22 AM »
Chryco, I didn't see any holes but there was a notch. I have attached a picture of a similar one that I found on the internet. What do you think?
Offline Jesus H Chrysler
« Reply #5 on: October 28, 2013 - 09:41:43 AM »
I don't know specifics about the flywheel, but I do know that externally balanced 340's had a different harmonic balancer that said "Use with cast crank 340 only"  That's one way to know if it's external balance without dropping the pan.
Yes I own a 1972 Dodge Challenger Convertible T/A S/E with a 440 Six Pak. Can it get any more wrong?
{OO /===\ OO}
(OO==> <==OO)
Greg, in the middle of MA has:
1970 Dodge Coronet 440 "Zom Bee"
1972 Dodge Challenger convertible 440 5 speed.
1973 Dodge Challenger 318 "Brown Bomber"
2012 Dodge Challenger R/T Classic Blackberry Pearl.
2001 Jeep Wrangler locked, lifted and lighted.  "Jeep is a registered trademark of Chrysler Corporation"
« Reply #6 on: October 28, 2013 - 10:15:48 AM »
Definatly a balanced flywheel but probably for a different application , there are numerous external offset balance engines , 340 , 360 , 383 cast crank , 400 & 440 6 pack with HD con rods & they use different offset weight so if you have a vibration & the book lists a 3 hole application your flywheel is from a different combo . The best way to solve this is have the engine balanced before assy adding metal internally to achieve a neutral external balance or at least exactly dialing in the balance of all rotating parts so you have not vibration but I am sure you do not want to tear down the engine to do this !
Offline cjm
« Reply #7 on: October 28, 2013 - 12:03:57 PM »
The crank (cast - stock )& balancer are correct for the engine. It came from a car that had an automatic trans, so the flywheel was added...  This was done a long time ago...  It's just the flywheel that I am not certain about. I guess I could just order a new one for that year and swap it out..
