Author Topic: Alternator 1 wire vs 2 wire...  (Read 677 times)
Offline anlauto
« on: October 25, 2013 - 04:07:41 PM »
Okay...This could be a simple question...Not sure....
A customer supplied an aftermarket chrome alternator for his car, .except he messed up and ordered a "1 wire" set up-up.
It looks like the standard 2 wire "square back" Chrysler alternator but it looks like they added an external regulator and a couple of wires pluged into where the wire harness usually plugs into on a two wire set-up.
Can I simply remove that regulator and wires and run it as a 2-wire set-up ?
« Last Edit: October 25, 2013 - 04:13:18 PM by anlauto »
Re: Alternator 1 wire vs 2 wire...
« Reply #1 on: October 25, 2013 - 05:40:29 PM »
I would say yes , if the two brushes are still connected to the field terminals I& the diodes are connected as per factory it should work properly
