Author Topic: Help, new dash harness install, no brake lights  (Read 582 times)
Offline Recovering Cuda
« on: October 25, 2013 - 05:22:18 PM »
Ok guys,  I just installed my new under dash harness.  Everything is good except I have no brake lights.  I looked under the dash at the brake light  switch and there is nothing connected to it.  There are two prongs (blade connectors) on the switch but only one looks like there was anything ever connected to it.  I don't remember pulling any connections off of the brake switch.  I have a pink and white connector hanging from the new harness and I plugged them in but Nada, nothing.     I checked my old harness but I still don't see where that connection is.  I looked at a wire harness diagram and did not see anything about the brake light switch.
any and all help is appreciated.
Re: Help, new dash harness install, no brake lights
« Reply #1 on: October 25, 2013 - 05:42:57 PM »
Pink & white is correct , connect the 2 wires together & see if the lights come on , if they do the switch is bad
 , if they do not then you may have a problem in the turn signal switch so you can test power to the column plug , white into the switch & see if the power returns to the brake light wires  green & brown maybe ?
« Last Edit: October 25, 2013 - 05:46:40 PM by Chryco Psycho »
« Reply #2 on: October 26, 2013 - 06:57:22 AM »
thanks Chryco.    I'll give that a try.   But now I have another issue so I will start a new thread.   Feel free to solve my next issue.........and the gremlins just keep on coming.
Re: Help, new dash harness install, no brake lights......Solved
« Reply #3 on: October 26, 2013 - 04:18:38 PM »
Thanks again.  I initially only hooked up one wire at a time.  Now that both the white and pink are connected.......I've got my brake lights back.
