Author Topic: What harness for the engine  (Read 661 times)
Offline Tropicalcats
  • Don't Ever, Ever Give Up
« on: October 25, 2013 - 07:47:24 PM »
I am updating all the wiring harnesses in my car and need to know if this is the correct one for me. I have a 383 Challenger R/T from LA and I will be going to a electronic ignition kit when I put the car back together. what hareness do I need?
https://www.yearone.com/Product/1966-74-a-b-e-body/hu107em
OR
« Last Edit: October 25, 2013 - 07:49:51 PM by Tropicalcats »
SOLD
Offline 72cudamaan
Re: What harness for the engine
« Reply #1 on: October 25, 2013 - 08:44:54 PM »
What kind of ignition system are you using ? If using the Chrysler electronic ign. then it says to use
the first one listed. The second one is for the unmodified point system.
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #2 on: October 25, 2013 - 08:54:42 PM »
Ok makes sense
. I will be using
Item# MRE-6993
Product Description
Electronic, Magnetic Pickup, Mechanical, Vacuum Advance, Chrysler, 361, 383, 400
Note: Includes an Mopar Performance P4120505 orange electronic control box, ballast Resistors and wiring harness.
These electronic distributors are blueprinted and feature a factory-set performance advance curve. They include an adjustable vacuum advance unit and a premium distributor cap and rotor with brass contacts for maximum conductivity. Available for different engines, the electronic distributors will keep your engine running consistently throughout the entire rpm range.
So it's the first one or the HUE 107 em that I want. right?
SOLD
Offline 72cudamaan
« Reply #3 on: October 25, 2013 - 11:08:45 PM »
yep.
