Author Topic: What is this attached to the steering shaft?  (Read 2953 times)
Offline AU6pack
« on: October 26, 2013 - 11:18:48 PM »
Hi there.
I need to install a hydraulic master cylinder under the brake booster. There is a long ear that is attached to the steering rod with turns about 90 degrees but has no obvious purpose (that I can see anyhow).
It will foul on the cylinder so it has to go. But what is it for and can i remove it?  :clueless:
HELP!
Craig
Melbourne, Australia
1970 Challenger 416 6 pak
Resto thread - http://www.cuda-challenger.com/cc/index.php?topic=114787.0
Re: What is this attached to the steering shaft?
« Reply #1 on: October 26, 2013 - 11:22:05 PM »
Lockout linkage I believe. Can you get rid of it? Yup, I did.
Offline AU6pack
« Reply #2 on: October 26, 2013 - 11:25:05 PM »
Thanks - any tips on getting it out?
Craig
« Reply #3 on: October 26, 2013 - 11:30:56 PM »
Well I did it a long time ago (15-20 years) so the memory is a bit fuzzy, but I had the steering shaft removed from the car. In the workshop I rebuilt the column without the lockout. It is a fairly long tube piece if
I remember right. Don't think you can remove it without disassembling the column.
« Reply #4 on: October 27, 2013 - 01:03:13 AM »
Remember if that lever is not in the right position the car won't start.....  Just thought I'd throw that out there?
Offline AU6pack
« Reply #5 on: October 27, 2013 - 02:46:17 AM »
Can I get a little more info on that comment? This ones got me a bit baffled...
If its removed then the car wont start? If i can't remove it I cant bet the master cylinder in? Should there be something attached to it??
Craig
Offline Finoke
« Reply #6 on: October 27, 2013 - 07:29:14 AM »
I think the car starts but the steering wheel is locked. PUll it up and see. It should rotate smoothly. It will probably lock the steering wheel.
« Last Edit: October 27, 2013 - 07:31:20 AM by Finoke »
« Reply #7 on: October 27, 2013 - 08:16:38 AM »
You can cut off the lever but the "stub" has to be in the correct spot to start, take out the key too I think?
Offline HP_Cuda
  • Mopar or No Car!
« Reply #8 on: October 27, 2013 - 01:27:49 PM »
I removed mine and when you do the lockout attaches to the lower piece below the ignition switch, you can then turn it clockwise or counterclockwise. Actually can work as a theft deterrent for those or are theft challenged.
 :clapping:
Offline Katfish
  • 70 Challenger
« Reply #9 on: October 27, 2013 - 05:54:01 PM »
I wondered about this too.  Should there be something connected to the tab in the engine compartment?
If not, what's the p[point of the hole in the lever?
« Reply #10 on: October 27, 2013 - 06:45:58 PM »
Yes, there is supposed to be linkage that goes down to the transmission. Mine is missing too.
« Reply #11 on: October 27, 2013 - 10:52:03 PM »
Hmmm. Just tossed mine and forgot about it. No issues.
Offline AU6pack
« Reply #12 on: October 29, 2013 - 06:58:51 AM »
Thanks for the replies guys  :2thumbs:
Craig
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #13 on: October 29, 2013 - 07:56:57 AM »
this is the lock out linkage.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
