Author Topic: 727 knob adjustment.........???  (Read 2536 times)
Offline DAYLEY/CHALLENGER
« on: October 28, 2013 - 04:42:37 PM »
I can't get the tranny to go into 1st manually......I push down on the button and it will only go to 2nd.  I tried to adjust the knob outward one turn and the button flies off........spring too.  I know there is a flat spot for the allen to set on and I think I can get the knob to hold if I rotate 1/2 turn but that just isn't right.......Are the threads in the plastic button worn to the point that I have lost the adjustment ability?   I know this must sound simple to most folks and it does to me too BUT.....why is it most of the simple things that create the most havac.  ?? :pullinghair: :pullinghair:
Dave or David
Re: 727 knob adjustment.........???
« Reply #1 on: October 28, 2013 - 06:35:48 PM »
Yup , you either need to helicoil the knob or replace it to get the adjustment back , crappy design from the factory
Offline hemiken
« Reply #2 on: October 29, 2013 - 06:38:41 AM »
Try taking the knob off completely to see if the shifter is going through the whole shifter range. This will tell you for certain that the shifter is not at fault. And i agree with CP, a fix would be to replace or helicoil it. :2thumbs:
Offline JayBee
« Reply #3 on: October 29, 2013 - 08:48:05 AM »
I had to buy another black push button just for that reason.
One day, the old one, flew up like a rocket while my top was down. Thank God I was stopped at a light and it landed on the back seat. I still keep the original (& an allen key) in the glove box, just in case.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline CUDA JAS
  • vroooooom!
« Reply #4 on: October 31, 2013 - 08:54:33 AM »
wait what...the **** button has an adjustment???
Ummm, can you explain this for me....so much still to learn!!
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline Katfish
  • 70 Challenger
« Reply #5 on: October 31, 2013 - 09:15:15 AM »
Same here, had mine apart several times, didn't see any way to adjust?
« Reply #6 on: October 31, 2013 - 01:16:22 PM »
once you release the allen screw locking it in place the whole assy rotates , the outer ball & the inner black knob , the more you tread it on the les the rod is depressed by the black button so you have to thread it on far enough to hold the botton on but not so far you cannot depress the button enough to get below the detent
« Reply #7 on: October 31, 2013 - 07:26:04 PM »
I'm glad someone else has had this issue......well not to wish bad luck on anyone else........OK..........the only place I have found a button for sale seperate from the whole knob assembly is Classic Industries........$8.99 and the shipping is   :pullinghair: :pullinghair:  $9.95.      Anyone wish to chime in.??  Thanks in advance.
Dave or David
« Reply #8 on: October 31, 2013 - 09:45:47 PM »
I just dug through my pile, found a 70 shifter and knob. It's used but yours if you can use it? It's all black?( the push button) threads look intact?  PM me your name and address and I'll pop it in the mail for you?
« Last Edit: October 31, 2013 - 09:47:49 PM by brads70 »
« Reply #9 on: November 01, 2013 - 01:10:06 AM »
Or it is a good time to upgrade to Steve / Quapmans pistol grip conversion
« Reply #10 on: November 01, 2013 - 06:24:47 AM »
I could convert..........but just to keep it mostly orig......I think I will go with Brads offer.   PM.....on the way. :2thumbs: :2thumbs: :2thumbs:
Dave or David
« Reply #11 on: November 01, 2013 - 06:28:27 AM »
That's what I did. I really like the pistol grip! :2thumbs:
