Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Vibration?
« previous
next »
Print
Pages: [
1
Author
Topic: Vibration? (Read 1080 times)
Dusty1
Jr. Member
Revived
Vibration?
on:
October 28, 2013 - 09:07:49 PM »
I have a vibration coming through the drive train that starts around 50 mph and gets a little worse going faster. Its a fast roughness not a shimmy or shake. Drive line looks fine & tight. I did find movement in the rear wheels like a bad wheel bearing. Top & bottom and side to side I get a little free play just like a bad front bearing gives. I'm thinking when I take the wheel off I won't be able to move it any more. (new bearings) Any ideas where to look when pull the wheels? Both sides do it but the right side a little more. Thanks!
Logged
Garys 1972 BS
Chryco Psycho
Administrator
C-C.com Guru
Re: Vibration?
Reply #1 on:
October 28, 2013 - 11:54:34 PM »
the axle brgs can feel loose if the end play is not set properly , you only want approx. .010 of end play in & out
Logged
Dusty1
Jr. Member
Revived
Re: Vibration?
Reply #2 on:
October 30, 2013 - 01:09:23 AM »
Could I feel that .010 when I shake the wheel from side to side?
Logged
Garys 1972 BS
Chryco Psycho
Administrator
C-C.com Guru
Re: Vibration?
Reply #3 on:
October 30, 2013 - 07:21:54 AM »
barely , if you can feel more than a slight bump it is excessive
Logged
Dusty1
Jr. Member
Revived
Re: Vibration?
Reply #4 on:
October 30, 2013 - 09:13:24 PM »
It is just feelable, not a loose feeling. I expected a solid feel. Maybe it is coming from my drive line not balanced well enough. Thanks for the help and for being patient enough to answer our sometime feeble questions.
Logged
Garys 1972 BS
Chryco Psycho
Administrator
C-C.com Guru
Re: Vibration?
Reply #5 on:
October 30, 2013 - 10:34:53 PM »
you can use a couple of hose clamps to try to dial in an off balance drive shaft
Logged
Dusty1
Jr. Member
Revived
Re: Vibration?
Reply #6 on:
October 31, 2013 - 11:01:37 AM »
Really? I never heard of that, I wonder if there is any trick you don't know about on these cars! What diameter are they, about three inches? Thanks again!
Logged
Garys 1972 BS
Chryco Psycho
Administrator
C-C.com Guru
Re: Vibration?
Reply #7 on:
October 31, 2013 - 01:37:50 PM »
depends on which end but 3-4" the worm gear adds a small amount of weight to one side of the driveshaft move them approx. 45* at a time.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Vibration?
