Author Topic: Holley 3310 750cfm  (Read 2876 times)
Holley 3310 750cfm
« on: October 30, 2013 - 07:03:41 PM »
Ive had this carb for a long time. But I don't think I've gone through one trouble free cruising season. today as I was on what is probably the last cruise of the year, I had backfiring on deceleration.
When I parked at home, I found there was gas seeping from the rear float bowl. Air bleeds were wet. Gas pooled on the intake. I had checked float levels 4 weeks before.
Are all holleys this problematic? I think I'll go proform or?????? next year.
Re: Holley 3310 750cfm
« Reply #1 on: October 30, 2013 - 07:16:41 PM »
the Holley design can be problematic , the cars sit too much in Canada the gaskets dry out , powervalve diaphragms harden etc , gasket tech has improved , the fuel is much worse with all the alcohol in it . Just installing a new kit with all new gaskets & parts like needle & seats & powervalves will help for a year or 2
. Many switch to Carter / Eddy design as at least the fuel cannot leak out but the tunability is far worse .
Proform / QFT is the best I have found , Proform is slightly cheaper & they are both great for tunability .
 the ultimate is multiport EFI of course .
« Reply #2 on: October 30, 2013 - 07:24:37 PM »
Well I agree with that but it's a little pricey for me at the moment. With a 440, 4 sp, 3.55 gearing, what cfm would you recommend 950? 850?
« Reply #3 on: October 30, 2013 - 07:31:10 PM »
850 cfm assuming you are redlined around 6000
 the 3310 is one of the oldest designs of Holley carb dating back to the 60s , they are decent or they would not still make them but you can definatly improve
Offline cudabob496
« Reply #4 on: October 30, 2013 - 08:16:08 PM »
I'd go mechanical secondaries
2011 Kawasaki Z1000
« Reply #5 on: October 30, 2013 - 09:56:33 PM »
« Reply #6 on: October 30, 2013 - 10:21:12 PM »
How come? I thought, when properly set up, vac sec was better. From Brads post, he agrees with you.
School me.
(By the way, not a cheap carb Brad  :money:)
« Reply #7 on: October 30, 2013 - 10:33:36 PM »
I have always preferred mechanical secondaries as well , you may or may not be able to floor the throttle from idle but punch it wide open at 2000 rpm & it will hit a lot harder than waiting for the vacuum to open the secondaries
Offline cudabob496
« Reply #8 on: October 30, 2013 - 11:06:00 PM »
School me.
secondaries are discussed here:
http://www.hotrod.com/pitstop/1306_vacuum_or_mechanical_secondary_carburetor/viewall.html
http://holley.com/TechService/FAQ.asp
« Last Edit: October 31, 2013 - 01:25:59 AM by cudabob496 »
2011 Kawasaki Z1000
Offline Super Blue 72
    • Phil's Super Blue '72
Offline mopar jack
« Reply #10 on: October 31, 2013 - 10:56:56 AM »
I've used the same 3310 holley on my 440 for 16 years and it would leak at the bowl gaskets on a yearly basis. However over time I have upgraded gaskets and at the start of spring I check the bowl screws for tightness and no issues.
Jack
Offline HP_Cuda
  • Mopar or No Car!
« Reply #11 on: October 31, 2013 - 12:39:00 PM »
Vac secondaries are great if you don't like dumping a boatload of fuel all the time.
 :money:
« Reply #12 on: October 31, 2013 - 12:40:38 PM »
True , but if you want to "play" then ya gotta pay? I have a 3310 here all rebuilt and ready to go. I ran it for years on my 383 Chevy. Worked OK....
Offline HP_Cuda
  • Mopar or No Car!
« Reply #13 on: October 31, 2013 - 12:49:00 PM »
Hey Brad
I remember you had a jetting problem with that carb, did you go up or down in jets?
B
« Reply #14 on: October 31, 2013 - 12:51:22 PM »
Hey Brad
B
Down in the front but up in the rears, had a heck of a time with squirters though. Used a really big on in the back to get rid of the bog. Finished with tuning the pump cams... still not perfect but much better. Every engine/location will be different though.
