Author Topic: Holley 3310 750cfm  (Read 2874 times)
Re: Holley 3310 750cfm
« Reply #15 on: October 31, 2013 - 01:33:28 PM »
Probably needed a heavier spring in the rear so it would open slower & reduce the bog , this is one of the main problems with the vacuum secondary , there is only 1 squirter to cover both so you end up with a larger on in front wasting fuel everytime you open the throttle , the mechanical will easily match the fuel economy IF you can keep your foot out of it .... good luck !!
Offline anlauto
Offline HP_Cuda
  • Mopar or No Car!
« Reply #17 on: October 31, 2013 - 02:38:41 PM »
Thanks Brad
I'm thinking of going the proform route after I get everything settled in later.
So you were starving the secondaries eh? How many steps up did you have to go on the rear squirter?
Any off idle stumble?
B
Down in the front but up in the rears, had a heck of a time with squirters though. Used a really big on in the back to get rid of the bog. Finished with tuning the pump cams... still not perfect but much better. Every engine/location will be different though.
Offline mopar jack
« Reply #18 on: October 31, 2013 - 04:40:54 PM »
Vacuum or mechanical, every time they open it's like flushing a toilet!
« Reply #19 on: October 31, 2013 - 05:08:45 PM »
Thanks Brad
B
[/quote
There is no rear squirter on a 3310
« Reply #20 on: October 31, 2013 - 05:46:36 PM »
Thanks Brad
B
[/quote
I was referring to the Quickfuel carb not the 3310
Offline HP_Cuda
  • Mopar or No Car!
« Reply #21 on: November 01, 2013 - 02:48:40 PM »
Talking proform, notice "proform route"... :bigsmile:
Thanks Brad
B
[/quote
« Reply #22 on: November 01, 2013 - 07:33:02 PM »
I'm thinking this will be one of the winter upgrades.
http://chucker54.stores.yahoo.net/850cfmprrase.html
I checked my bill file and I bought the 3310 in 1987. Wow. Doesn't seem like 26 years ago. Must be getting old.. Bought it when I was 23...
