Author Topic: How do I swap a 3 on the tree to 3 on the floor?  (Read 3017 times)
Offline PlumCrazyChris
    • Mopar Muscle Cars of Austin
« on: November 01, 2013 - 10:47:16 AM »
I'm thinking of picking up a new project that has a 3 on the tree.   I'd want to swap it to a floor shift right away.  I had a manual 3 speed in my first challenger and didn't mind it a bit, it was pretty cool once I finally got the linkage and shifter working correctly.   That was many moons ago.
What do I need to install a floor shift instead of the column shift?
Is there a bracket on the trans for the shifter to bolt too?
Do I need new shifting rods?
Can you still get a 3 speed shifter for that application?
Any help you can give me would be great!
Thanks,
Chris
PlumCrazyChris
Round Rock Tx
70 Challenger 5.7, A518, A/C
70 Challenger 340 convertible (Gone to Sweden)
68 Barracuda (sold it too)
www.mopar.org
Re: How do I swap a 3 on the tree to 3 on the floor?
« Reply #1 on: November 01, 2013 - 06:37:51 PM »
you will need the shifter mount bracket & shifter as well as the rods & probably a floor hump to clear the shifter as well , not sure where to find the shifter , I would start with swap meets or used parts dealers
« Reply #2 on: November 01, 2013 - 09:28:50 PM »
Sounds easy enough, anyone have  leftover 3spd they swapped for a 4spd?
I wonder if the generic ones they sell in Summit would work?
Thanks Chryco
PlumCrazyChris
Round Rock Tx
www.mopar.org
« Reply #3 on: November 20, 2013 - 12:14:23 AM »
Does anyone know if you can get a new shifter to work wirh factory 3sp?
Also, what IS the 3spd trans called?
Thanks
PlumCrazyChris
Round Rock Tx
www.mopar.org
« Reply #4 on: November 20, 2013 - 12:43:59 AM »
One other thing to do is to completely dissamble the steering column and transplant the shift indicator portion to a non type like what floor shift car columns are like.
« Reply #5 on: November 20, 2013 - 10:58:29 AM »
I do not know if there is even a new shifter availble that would work on a 3 spd & I cannot remmeber what the Axxx code is for the 3 spd
Offline Jamiez
  • Retro
« Reply #6 on: November 20, 2013 - 11:04:51 AM »
Three speeds are A230s
« Reply #7 on: December 19, 2014 - 11:21:14 AM »
So it sounds like the shifter is mounted to the floor bracket instead of the transmission, is that right?  Or is there a bracket that you add to the trans?
Thanks
PlumCrazyChris
Round Rock Tx
www.mopar.org
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #8 on: December 19, 2014 - 04:52:15 PM »
I'm curious as to whether or not the three on the tree has a floor hump added for the manual trans.  Regardless of the shifter.
You might get lucky with that one and not have to graft in a new floor hump and cut out the auto hump.
« Reply #9 on: December 19, 2014 - 04:53:31 PM »
If you put a wanted add on a few mopar boards, I'm sure you will come up with a three speed that someone doesn't need from a 3 to 4 speed switch.  Pretty common item.
Offline Road_Runner
« Reply #10 on: December 23, 2014 - 11:30:01 PM »
I'm sure you've thought of this, but since you're already modifying the car why not just go to a 4 speed / pistol grip?  Parts would be easier to find and possibly cheaper since they're more common.  Just a thought.
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
« Reply #11 on: June 21, 2015 - 11:31:29 PM »
My thought it just to slap a floor shifter on it in an afternoon and keep it on the road.   I don't have the project car yet, but seem to come across three on the tree semi-regularly and thought that would be more fun to tool around town with a floor shift.
PlumCrazyChris
Round Rock Tx
www.mopar.org
