Author Topic: 1973 cuda stock rear widest tires without any mods?  (Read 21114 times)
Offline anlauto
Re: 1973 cuda stock rear widest tires without any mods?
« Reply #15 on: November 03, 2013 - 12:06:57 PM »
Well I just figured out nobody makes a 275/45/17 tire... :smilielol: I guess that's why everybody has 275/40/17's :pullinghair:
How can I get taller without getting wider ? or narrower for that fact ?
« Reply #16 on: November 03, 2013 - 12:30:31 PM »
Back to the usual problems sizing muscle car tires , there is a 275 55 19 Nitto
Offline 7212Mopar
« Reply #17 on: November 03, 2013 - 12:39:41 PM »
 :rebel:Nitto NT450, 275/50/17.
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ,  6 spd
Offline anlauto
« Reply #18 on: November 03, 2013 - 12:59:20 PM »
These are 11.06" wide according to their web site...Will that still fit in an E Body wheel well ?
I was also looking at Nitto 255/50R/17's at 10.16" wide
Offline anlauto
« Reply #19 on: November 03, 2013 - 01:51:20 PM »
Okay...So I think I've found the tires (after 2 hours on the computer)...Then I search YearOne's web site only to find out the 17 X 8 Magnum style rims are not available :banghead:
« Last Edit: November 03, 2013 - 04:40:07 PM by anlauto »
Offline 7212Mopar
« Reply #20 on: November 03, 2013 - 01:52:29 PM »
275 will fit
Offline anlauto
« Reply #21 on: November 03, 2013 - 01:56:49 PM »
275 will fit
The Nitto 275/50R/17 on a 17 X 9 rim with a 5" back spacing will fit on a Challenger without modifications ?
Is that your final answer ?
Can I get that in writing before I order them ? :roflsmiley:
Offline 7212Mopar
« Reply #22 on: November 03, 2013 - 02:11:48 PM »
Tires are like chocolate, you never know what you are going to get.
« Reply #23 on: November 03, 2013 - 04:02:53 PM »
the tire will fit fit for sure , the 275 fit well & on a 17 " rim you will have less sidewall , the rim backspace would be my only worry
Offline anlauto
« Reply #24 on: November 03, 2013 - 04:03:33 PM »
:clapping:  :roflsmiley:  :cheers:
Offline anlauto
« Reply #25 on: November 03, 2013 - 04:11:17 PM »
Comparing a 275/50R/17 to a F60X15 (which is the standard tire on a Hemicuda), they would be about 1 3/4" taller which shouldn't be a problem, and about 1 1/2" wider. Stock back spacing is 4 1/2" on a 15X7 rim so we're not talking huge differences here... :2cents:
Can someone please buy a set and let me know... :bigsmile:
« Reply #26 on: November 03, 2013 - 05:06:01 PM »
I used this to compare to the standard 255/60/15 that's common. Not much difference in width or height. I say go wider! :grinyes:
http://www.tacomaworld.com/forum/tirecalc.php?tires=275-50r17-255-60r15
Offline anlauto
« Reply #27 on: November 03, 2013 - 05:12:04 PM »
I saved that link last time you posted it  :2thumbs: That's what I've been using all afternoon :cheers:
« Reply #28 on: November 03, 2013 - 05:13:00 PM »
:2thumbs:  You can easily fit wider tires still. I'm planning 295/40/18, they are pretty close to 295/50/15 which is also common to use on e-body's. Trick is the rim backspacing, I bought the B-Body width Dana in anticipation for wider rubber.
« Last Edit: November 03, 2013 - 05:15:57 PM by brads70 »
Offline Dusty1
  • Revived
« Reply #29 on: November 04, 2013 - 09:14:26 PM »
B F Goodrich T A Radial 295-50-15 on 8.5 wheel & 4" BS. 26" tall & 12" wide
Garys 1972 BS
