Author Topic: help identify what these are and where they go  (Read 889 times)
Offline AZDAN
« on: November 02, 2013 - 01:28:17 PM »
Can someone tell me what this is for and where it goes. I'm guessing it goes with the dash wiring harness? On the heat A/C does the blue wire go on the top or bottom tab in the photo?
« Last Edit: November 02, 2013 - 01:44:53 PM by AZDAN »
Offline Rich G
Re: help identify what these are and where they go
« Reply #1 on: November 02, 2013 - 03:03:00 PM »
Top one goes the gauges. The relay looks like a horn relay .
« Reply #2 on: November 02, 2013 - 03:03:44 PM »
picture 1 is the voltage reg , black wire connects @ one end & the 3 blue wires feed power ou to the fuel temp & oil gauge
Pic 3 is the horn relay
pic 4 is the headlight dimmer plug on the floor
picture 5 if the lighter wires are orange then it is the power plug for the radio
« Last Edit: November 02, 2013 - 03:07:32 PM by Chryco Psycho »
Offline AZDAN
« Reply #3 on: November 02, 2013 - 03:49:09 PM »
Picture 4 is on he pasenger side of the dash. I have the dimmer switch on the drivers side. Could it got the A/C blower motor?
« Reply #4 on: November 02, 2013 - 04:25:41 PM »
Green could definatly be the fan motor plug
Offline anlauto
« Reply #5 on: November 02, 2013 - 04:28:16 PM »
#2 A/C control
#3 Door buzzer
#4 is A/C fan control, yellow are door jamb light switch
#5 blue/purple is seat belt warning dash light, other plug is radio
« Last Edit: November 02, 2013 - 04:30:59 PM by anlauto »
