Author Topic: THermoQuad Question  (Read 1505 times)
Offline anlauto
THermoQuad Question
« on: November 02, 2013 - 07:09:04 PM »
I have a customer that supplied a 9292S for his 440, I believe it's a 1975 unit.
Where can I find a diagram that shows me where all the hoses hook up ? looks like a lot of extra nipples on this thing... ;)
Offline Skunkworks Challenger
  • Mopars forever!
Re: THermoQuad Question
« Reply #1 on: November 02, 2013 - 07:44:27 PM »
http://www.carburetor-parts.com/
This guy has lots of TQ parts and information.
The Brewmaster
« Reply #2 on: November 02, 2013 - 07:54:25 PM »
This is a '73 I believe....there may be extra ports on the newer ones but these should all be there & are all that are necessary..Cap any extras.
Offline anlauto
« Reply #3 on: November 02, 2013 - 08:26:31 PM »
That does help a little...The confusing thing is that it appears to have two large nipples for the PCV...one in the front and one in the back :clueless:
Offline Challenger6pak
« Reply #4 on: November 02, 2013 - 08:35:37 PM »
Does this carb have the electric vent unit on it?  Post a pic.
Offline anlauto
« Reply #5 on: November 02, 2013 - 09:17:46 PM »
It's freshly rebuilt, flow tested set-up etc...
« Reply #6 on: November 02, 2013 - 09:29:16 PM »
It's called a bowl vent....relocated starting in '78 from the top of the carb as in earlier models
If your using the charcoal canister this would be where the big hose goes I suppose
                     See section called Port Diagram
http://www.carbkitsource.com/carbs/tech/Carter/pages/tqguide-Vaanth.html
9292S is from a 1980 Truck 360 ...
« Last Edit: November 02, 2013 - 09:41:34 PM by Bullitt- »
« Reply #7 on: November 04, 2013 - 10:35:08 AM »
Offline FISH FRY
« Reply #8 on: May 13, 2014 - 08:51:50 AM »
 :wavingflag:
The TQ is a master piece.  on reassembly ,don't forget the rubber seals at the bottom of each well .  if it bogs on back barrel hit the air door spring is too loose
               or way too tight.  lift rod center adj ,leans out the front .  and i'd have to say i got a couple more mpg with mine. ran well on hot days
